Go to Post At least I can appreciate the humor in this LOLCODE; it isn't funny when our our robot goes backwards in hybrid mode - sgreco [more]
Unread 25-01-2012, 13:33
BrandonGlatz BrandonGlatz is offline
Sparky
FRC #2865 (Roboteknix)
Team Role: Electrical
BrandonGlatz is on a distinguished road
Looking for a connector
{I'm not new here, for some reason my old account was deleted }
So This year for my control system, I am putting it in a box for protection. The only outside interface will be for the motors.
I am trying to find a connector that will be able to handle 28 or so motor-gauge wire. I would prefer one connector, but if it requires up to three that would be fine.
Anyone have any suggestions or recommendations for connectors that would accomplish this?
Unread 25-01-2012, 13:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Looking for a connector
I suggest you keep the motor wires separated by motor, so if you have to replace or troubleshoot a motor, it will be a lot easier.
PA45 Anderson Powerpole connectors work well, you can pair them, use different colors, and they are pretty reliable.
Unread 25-01-2012, 13:41
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I'd start by looking at the Delphi Metri-pack series of connectors. Be careful though as you will find a number of connectors that have terminals that will accept up to 12 ga wire but are not rated to carry the full current capacity of a 12ga wire. They are only set up to accept that large gauge wire to prevent voltage drop. Also a given connector has a maximum total amperage capacity that again is not based on the size of the wire that terminals that will fit it are capable of handling. So you may find that 28 position connector that will accept terminals that can handle 40 amps each but not 400 amps that would result from 5 pairs of terminals carrying 40 amps.
Unread 25-01-2012, 13:43
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Checkout the Anderson Power Pole series. the PP45's can handle up to 45A, so they're great for our applications. It's a single connector for each lead, but they interlock together to form larger connectors very easily. They also give you good polarity protection when you lock two or more together, as there's only 1 way to plug them in (like the Anderson connector we use for the battery).
If you decide to go that route, I highly recommend getting a proper crimper for them, like the one available here: http://www.westmountainradio.com/pro...ts_id=PWRcrimp
Unread 25-01-2012, 13:44
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
In previous years, we used the Anderson Powerpole connectors for motor power and DB37 or DB25 (multiple of them if necessary) for signals. You don't really want power wires to go in the same bundle with the signal wires anyway. They might inject noise to your signal wires.
Unread 25-01-2012, 14:38
Mr V's Avatar
FRC #5588 (Reign)
Note those are only rated for 45A when used with 10 ga wire in a single configuration. With a 12ga wire they drop to 35A in a single configuration. Connect them in a multiple configuration and with the 10ga wire the rating drops to just over 30A per terminal, with 12ga it is just over 20A per terminal for loads occurring for more than ~1 minute.
http://andersonpower.com/files.php?file=DS-PP45(6).pdf
As I noted above you need to consider not only the size of wire it will accept, but the ampacity of the terminal and the ampacity of the connector as a system.
Of course that doesn't mean that you can't get away with it as we all do with the legal battery connector which is only rated at 60 amps when fitted with 6ga wire for the duration of a standard FRC match. Yet it is "protected" with a circuit breaker rated at twice that.
http://andersonpower.com/files.php?file=DS-SB50(3).pdf
Unread 25-01-2012, 15:15
MrForbes's Avatar
AKA: Jim
The motor wires are 14 gage, aren't they? yet teams have been "getting away" with using the PowerPole connectors for them for years. I haven't heard of any of them melting.
Most ratings are very conservative for what we're doing, what with the very short life expectancy we require of a competition robot.
Unread 25-01-2012, 15:39
Sparky
I never even thought about using those. that would be awesome because they can be attached to the side of my case easily... Where would I go to order them?
Unread 25-01-2012, 17:08
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
chi-town-biker is an unknown quantity at this point
http://www.powerwerx.com/anderson-powerpoles/
Unread 25-01-2012, 23:55
Sparky
I cant find any called a PA45 on their website... typo?
Unread 26-01-2012, 00:11
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
PP45 is the correct series.
http://www.powerwerx.com/anderson-po...ings-contacts/
The crimping tool that they sell in very good. We had some trouble last year getting the pins seated in the housing. Using their tool solved the problem.
http://www.powerwerx.com/crimping-to...-contacts.html
Unread 26-01-2012, 00:27
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
IMO, the only real acceptable application (for FRC purposes) of 28AWG wire is a circuit board - I wouldn't really be comfortable with it in any other situation. If you must, though, screw terminals may also work for you.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 26-01-2012, 00:34
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
on our 2009 bot we melted the Anderson powerpoles on our intake roller it got jammed and the powerpoles melted and dripped down our frame
i would definitely recommend deans convectors they are much better
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 26-01-2012, 07:46
Please remember that the current ratings on the Anderson connectors are the continuous duty ratings. These can be derated when used in an under three minute match. We have used the 45 amp connectors for at least 10 years now and have never had one fail. We use #10 for most applications involving high current motors. While it is difficult to insert #10, I spread the contact a little to help. Using the APP crimper (we got ours from West Mountain Radio) the contact is returned to normal and makes a great connection. As extra insurance, we add a little solder just to be sure.
The Anderson connectors can be stacked into multiple contacts that are also polarized. We have used up to sixteen contacts in one connector bundle in the past.
Unread 26-01-2012, 12:12
Sparky
Oh thanks then!
