Go to Post and thats my tip of the day. - Tytus Gerrish [more]
Unread 25-01-2012, 14:05
team3511 team3511 is offline
FRC #3511
team3511 is an unknown quantity at this point
Motors not running full speed?
Hello!
Originally we had thought that our code or the cRio was at fault, but it seems that swapping Java with Labview and the 2012 with the older 2011 cRio doesn't solve the issue of our motors running full speed.
The Jag's put out 12V, but the motors seem to be running significantly slower than last year.
What has been checked and is fine:
Code
cRio
Battery
Sidecar
Jaguars
Could it be a safety setting of some type in the new driver station software? Or maybe we're insane and the motors are fine?
Any thoughts are welcome, thanks!
Unread 25-01-2012, 14:07
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Motors not running full speed?
I'm not familiar with the jags, but is there some kind of calibration button? Or you could be crazy, ya never know.
Every day is a new adventure!!!
Unread 25-01-2012, 14:11
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by team3511 View Post
Hello!
Code
cRio
Battery
Sidecar
Jaguars
What motors? What gear ratios and end effectors are they connected to? How are you gauging "significantly slower"?
Not sure if Jags need it (probably not) but you may want to check its calibration and also ensure the cRIO and DSC are indeed putting out a full-speed signal. Read "12V" on a multimeter is not sufficient to determine if it is indeed sending full-speed power. Unless you see it as a solid 12V on an oscilloscope remain skeptical.
This might help: http://www.ti.com/lit/an/spma033a/spma033a.pdf
Unread 25-01-2012, 14:12
the man's Avatar
AKA: Jacob Overla
FRC #4004
Wont the signal light on the jag be solid red or green? Or is that only with the victors?
Unread 25-01-2012, 14:13
FRC #3511
I'm researching how to calibrate them... but I don't think that's the issue. I've tried the old Jags from last year and the result is the same. It's not the joysticks either as it preforms the same way in autonomous...
Unread 25-01-2012, 14:16
How about if the multimeter reads the same value at the Jag's power inputs and outputs?
Unread 25-01-2012, 14:22
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
That would be encouraging.
I will amend my original statement and say that I would remain skeptical using a multimeter unless I absolutely understood how it interpreted DC voltage readings.
I recall (in my ignorance) looking at a pulsed DC voltage signal with two different voltmeters and getting two different readings. Eventually I bought a multimeter with "true RMS" capability that provided a usable value.
Unread 25-01-2012, 14:24
FRC #3511
The speed difference is noticeable. Last year we could spin the tires in place if we really wanted, now it's hardly moving fast enough to keep up with someone walking.
We're using the CIM motors and toughboxes from andymark. Not sure of the gear ratios.
Will do more testing on the Jags' outputs tomorrow.
Unread 25-01-2012, 14:29
...a pulsed DC voltage signal with two different voltmeters and getting two different readings.
Fair enough.
Has anyone ever done any tests on a variety of voltmeters commonly used by FRC teams to determine how they respond to pulsed DC voltages? I searched but couldn't find anything.
Unread 25-01-2012, 14:33
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'd check your gear ratios and expected drive speed against your previous robot. It is easy to miss something like that.
Unread 25-01-2012, 14:48
jblay's Avatar
jblay jblay is online now
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Have you tried swapping to victors and seeing if the problem magically disappears? Every time we have a problem with a mechanism that uses jags we do this and it is magically fixed.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 25-01-2012, 15:19
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Assuming everything other than the ToughBox is from the KOP:
Let's start with some basic math. Last year's KOP transmission used a 4.66:1 ratio. It drove 8" wheels through a 2.17:1 chain sprocket reduction. So the overall reduction was 10.1:1 to 8" wheels. So for every revolution the motor makes, the wheel turns 2.49".
An AndyMark ToughBox has 12.75:1 reduction. Add to that the 2.17:1 chain sprocket reduction and the overall drive train reduction would be 27.66:1 driving 6" wheels. So for every motor revolution you get .68 inches of travel.
Yep, way slower. But, you might be able to climb a wall with that drive train!
Unread 25-01-2012, 21:00
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
How do you know the motors are running slower than last year? Are you basing this of how they sound? Were you running Victors last year? Victors and Jags run at different frequency's. I think, (but can't exactly remember if this is true) that Jags run at a higher frequency than Victors which would make the motor run quieter.
Unread 25-01-2012, 21:11
Is your software set up for jaguars? If your software references victors, but you're using jaguars, you will only see the jaguars run at approximately 75% of full speed.
Could you post your software?
Unread 25-01-2012, 21:47
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Just reading the posts made me suspect gear ratios. But people don't seem to be biting
Don't you hate it when people don't believe the "numbers"
Phil.
Phil Malone
http://www.GEARSinc.org
