Go to Post Pros of living in California from a Canadian standpoint: FRC on-field glass doesn't occasionally have shoe marks on it - Edxu [more]
Unread 25-01-2012, 14:55
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
Kinect Not Recognizing X and Z Axis
After deploying the robot code and enabling the code the y axis is only working. Tried doing movements after the program was disabled and still no movement on the kinect skeleton indicator for the x and z axis values.
Unread 25-01-2012, 15:48
Re: Kinect Not Recognizing X and Z Axis
As described in the Getting started with Kinect document, there are only pre-programmed gestures for the Y axis, and some buttons. If you want to define gestures for X and Z, you would need to modify the Kinect Server as described in the document.
