Go to Post but if you can build stuff, you can figure out how to build other stuff. - GeeTwo [more]
Unread 25-01-2012, 16:33
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
Default code
Do I have to edit the default code to get a motor hookup to work? I have deployed an unchanged code, all lights are green, and the motor is not running with joystick 1.
I get an axis camer not found in the driver station log as my only error and it is running through a jaguar. PWM 1 and 2 are hooked up with the three prong slot
Unread 25-01-2012, 19:53
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Default code
Is the light on the Jag solid or flashing orange? Did you image the Crio? Did you enable the robot on the driver station?
