Go to Post Stupid rules are not meant to be broken; they're meant to be changed. Unless and until they are changed, breaking them is wrong. - Alan Anderson [more]
Unread 25-01-2012, 16:34
mbram mbram is offline
FRC #3502
mbram is an unknown quantity at this point
Encoder Recommendation
Hey, our team 3502 is looking for something that could measure a wheel spinning at 1,000 - 2,000 RPM. We were told to look into a high speed encoder but we are having trouble finding the right one. Does anyone have any recommendations?
Unread 25-01-2012, 17:47
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Encoder Recommendation
Any incremental encoder that gives the appropriate output level should do. The question is: How clean will you be with your encoder? Remember that the little slits in that optical disk can easily be obscured by oils deposited when touching it.
If you are looking for something with a variable number of counts per revolution, look into the CUI AMT102 and AMT103. They are variable count devices, and they are easy to mount.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 25-01-2012, 22:29
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
We have had good results with some of the higher quality shaft encoders from US digital. The S-6 model has an index channel which handles speeds up to 100,000 RPM, however running in this mode disables direction sensing i believe.
