Go to Post hmmm... big open space between arena and pits... thousands of poof balls...thousands of high school kids hopped up on sugar and robotics.... sounds a little dangerous. - Courtneyb1023 [more]
Unread 25-01-2012, 17:12
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
pic: Polycord Welding
Unread 25-01-2012, 17:16
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: pic: Polycord Welding
We just use a bic lighter and hold both pieces over the flame. When they are both hot (or melting) we just shove both ends into each other. When cool, we hit it on a belt sander, and repeat the entire the process until the seam is smooth. Just try not to inhale that magic black smoke....
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 25-01-2012, 19:23
Our first tries were with fire, didn't like the fumes, burnt rubber smell, and the joints were less uniform. This really is simple. Used it last year and on our Lunacy robot without fail. Pull the trigger on the soldering gun until both sides melt, and slide out the gun. Let it cool for a few minutes, and trim off the part that mushrooms with side cutters.
Unread 25-01-2012, 22:27
AKA: Mason Falk
Yes, but how would MacGyver do it in a sealed room with only polycord and a bic? No, I agree, the less magic black smoke the better. You will live much longer doing it that way...
Northville, MI USA
Unread 28-01-2012, 12:54
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
I found an easier way to do it.
We did it a bit differently. Took a 1"x1"x.125"thick aluminum U-channel about 4 inches long. Then i hot glued two aluminum angles (1"x1"x.125" thick) about an inch long each into the channel with half an inch in between so the aluminum doesnt take away the heat and cause the belt to cool rapidly. heat the first quarter inch of each side of the belt over a heat gun, not a flame or soldering iron. The heat gun lets it cool easier. put one side of the belt in each angle piece, stick them together. hold for two minutes, the water cool under running water, as a bucket will force you to bend the connection. trim in with wire cutters and take it to the belt sander. dont hold the belt directly on the table for the sander, because it can rip it through the gap between the sander and the table and break the sander, get somebody hurt, and ruin the belt.
Good Luck Teams
Unread 28-01-2012, 19:32
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Any reason you guys are melting the polycord together instead of just tieing it?
My team has decided to go with tieing due to concerns about the melted together joint being weak and our inability to identify any benefit to melting it
Unread 28-01-2012, 19:46
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Unless you are doing something wrong then your joints should not break. I'd be more concerned with my knot untying or messing up the movement of the ball/rollers.
The way we have done polycord welding was with a heat gun (or flame but you have to keep the cords in a magic spot so they don't burn and so that they aren't too far away, heat gun preferred). Once you see the two cords turn liquidy on the end we pushed them together and held them for a minute or two until they cooled. Once they have set for a while we would take a knife and shave off the loose ends. We did this in 2009 and I can't remember a single joint breaking it is wicked simple and so easy I don't know why you would consider tying them.
Take a small segment and trying melting them together as a test before resorting to tying. A little too sketchy with polycord for me and I have never seen that done before.
1058 PVC Pirates 2016 - xxxx
Unread 28-01-2012, 20:13
Teams are melting it because that is the proper method for joining/welding it.
Welded joint is as strong as the cord itself. We pull test every joint, and have never had a failure in competition.
If your team does not want to join it with heat, I suggest using the hollow polycord with connectors or find another belt system to use.
Unread 28-01-2012, 21:34
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
For out polycord welding we milled out a simple assembly like above.
Two 1" blocks of aluminum are attached to a rail system on a base. The tops are notched to cradle the polycord.
On one of the sliders there is a hole just large enough to put the polycord through. Each end of the cord is slid through and cut against the face of aluminum with a razor blade so that it's perfectly flat.
The hot knife is then held between the seated ends. Once hot the rail cradles are slid together and form a clean and even "weld"!
I can upload some photos upon request.
Unread 28-01-2012, 22:24
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
I'd be interested in some pics. Thanks!
Unread 28-01-2012, 22:30
V_Chip's Avatar
Back in action.
AKA: Victor
I'll see if I can get some up by tomorrow or Monday night.
Unread 30-01-2012, 18:59
V_Chip's Avatar
Back in action.
AKA: Victor
Photos are here:
