Go to Post Your primary job is not to build the most technically advanced robot, but build the best possible team. - PayneTrain [more]
Unread 22-01-2012, 21:03
Nerdcube's Avatar
Nerdcube Nerdcube is offline
FRC #2851 (Crevolution)
Team Role: Webmaster
Nerdcube is an unknown quantity at this point
Team 2851 Shooter Prototype
Here is Crevolution's latest prototype making half court shots in the top net:
http://www.youtube.com/watch?v=dJGS8LPw1yg&context=C32d36d3ADOEgsToPDskLq JfQ1lfBz8rrN7E979ICk
We used 1 direct driven CIM motor, 8" wheels, and it is positioned 60" above the ground. Our plan is to use 2 Fisher Price motors on our robot.
And yeah, it's duct taped to a ladder.
Unread 22-01-2012, 21:11
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Team 2851 Shooter Prototype
Only 2 out of 3? What do you think caused that shot to be off?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 22-01-2012, 21:14
Nerdcube's Avatar
Inaccurate feeding is probably our biggest problem. Once we get a consistent feeding mechanism, we believe accuracy will greatly improve. And also the distance the ball travels through the air obviously creates variation.
"Always go to other people's funerals, otherwise they won't come to yours." - Yogi Berra
Unread 22-01-2012, 21:16
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Is that a single-wheeled shooter?
Unread 22-01-2012, 21:19
Nerdcube's Avatar
Yes. We like that design because of the backspin.
Unread 24-01-2012, 01:29
TEAMROCK2000's Avatar
TEAMROCK2000 TEAMROCK2000 is offline
FRC #2000
TEAMROCK2000 is on a distinguished road
how much did u guys pinch the ball
Unread 24-01-2012, 07:56
Squeakypig's Avatar
Squeakypig Squeakypig is offline
AKA: Mike Coyle
Squeakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond repute
I believe that our compression was about 2".
Unread 24-01-2012, 08:38
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Taylor Hawkins is an unknown quantity at this point
Have you guys thought about two wheels to help with accuracy? We found that with 2 8'' wheels spread apart a bit gave us better accuracy.
Take a look
http://www.flickr.com/photos/wileyb-j/6688012541/
Unread 24-01-2012, 19:59
Nerdcube's Avatar
Yeah, sorry, we actually did use that system. What I meant by one wheel is that it wasn't a pitching machine type approach, the ball was only being moved by one axle.
Unread 24-01-2012, 23:15
2386 BCHS Trojans
FRC #2386 (Trojans)
That makes more sense!
Unread 24-01-2012, 23:57
hsekhon27 hsekhon27 is offline
FRC #0280 (TNT)
hsekhon27 is an unknown quantity at this point
This might be because the ball had a different density. We built our prototype and it wasn't shooting all the balls at the same spot. We figured out that this was because many balls have different densities
Unread 25-01-2012, 15:27
Nerdcube's Avatar
Yeah, we actually just figured that out as well. When testing a brand new against a 2 week old ball, there was a great difference in the trajectory and the distance traveled. I think such long range shots in the competition are going to be pretty rare simply because the balls are so unpredictable. You might find a "sweet spot" in practice, but once you get a different ball that spot might change.
Unread 25-01-2012, 16:36
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
So for us more rookie type teams, what did you find necessary to help compensate for the aging balls? Faster shooter speed, more compression
on the ball (more than 2 inches)?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 25-01-2012, 18:20
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Take a look
Why do 2 wheels make it more more accurate? Also, would a wide roller serve the same purpose as 2 large wheels, or do you need 2 separate pts of contact?
Unread 25-01-2012, 18:31
2 wheels give a bit of a groove for the ball to "settle" into, resulting in the ball leaving from the same place every time (and thus having exactly the same spin every time). It's not really an accuracy aid, but a precision aid. A single wheel may have the tendency to let the ball slip sideways to one direction or the other, causing less-predictable spin.
A single wide roller could act like one wheel or two, depending on exact construction--with a shallow groove in the middle, or a groove/depression on the compression bar/hood, it'll act like 2; if neither has that, there's no telling. It might act like 1 or 2 wheels.
