Go to Post A person is not defined by what mistakes they make, but more so by what they do after they realize their mistake. - Andy Baker [more]
Unread 25-01-2012, 09:18
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
How to Remove Pinion Gear from FP-9015
Hey Roboticists,
We want to remove the pinion gear that comes on the FP 00968-9015 motors in order to attach them to the AM Planetary Gearboxes. What's the best way to remove the gear without damaging the output shaft?
I saw a thread from a few years ago that mentioned doing something similar, but was wondering if a better solution was out there.
Thanks!
Unread 25-01-2012, 09:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: How to Remove Pinion Gear from FP-9015
The 'right' way to remove the pinion is to use a Pinion puller similar to this one:
You should be able to find one at your local hobby shop, tell them you need a pinion puller for a 500-series motor - cost should be less than $20.
-Dustin Benedict
Unread 25-01-2012, 10:24
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The alternative - which is really just a wilder implementation of a pinion puller - is to cut a slot into a piece of steel (or similarly rigid material) such that it'll fit snugly around the axle, between the pinion and the motor, vise the piece with pinion up, motor down, then use a mallet with a pin punch to drive the motor out of the pinion.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 25-01-2012, 10:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Another alternative is to break the pinion gear (assuming you won't need it), using a nut splitter, or even a hammer and cold chisel and an anvil. The hammer method can be hard on the motor, so use it as a last resort.
Unread 25-01-2012, 10:36
thefro526's Avatar
Mentor for Hire.
This method is acceptable in a pinch, but it can damage the motor. I used this method to remove pinions from about a dozen tetrix motors last year and seemed to have damaged the bushings or some other internal part on one.
-Dustin Benedict
Unread 25-01-2012, 10:41
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Agreed, if you are going to try this one, be VERY careful, as you can damage the motor and potentially yourself The best way to do it is having an actual pinion puller, the "right tool for the job." I believe the phrase goes, "if it's hard to do, you're doing it wrong."
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 25-01-2012, 10:54
Coach/Mentor
AKA: Michael Liang
Thanks all, we ordered a pinion puller from Amazon.
Unread 25-01-2012, 11:01
Maxzillian Maxzillian is offline
AKA: Eric H.
FRC #0935 (RaileRobotics)
Maxzillian is on a distinguished road
Send a message via AIM to Maxzillian
This is the method I've always used. I usually take a dremel with a cut-off wheel and cut a deep slot, nearly to the shaft, along the length of both sides of the gear (180 degrees apart). This makes it very easy to split using a hammer and chisel.
Team 935 RaileRobotics Alumni: 2001-2004
Team 935 RaileRobotics Mentor: 2009-Present
Unread 25-01-2012, 18:27
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: How to Remove Pinion Gear from FP-9015
Pulling the pinion is the easy part. Putting the new one on is where you can easily bend the shaft. I recommend making a fixture to hold the motor square and use an arbor press with a faced push rod and relief hole larger than the shaft so the clearance hole will allow you to press the pinion to the proper height. Never press on the pinion if the shaft is not exposed, as this will Guarrantee a damaged and unusable motor.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 25-01-2012, 18:32
We have a mentor who is retired from the Motorola machine shop. He made a jig using either two pieces of steel or a single piece with the notch and set the motor and jig into a vise. He then used a pin punch in an arbor press and simply pushed the shaft out. It takes some patience but it comes out without damage to either the motor or the pinion.
Unread 25-01-2012, 22:14
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
If you don't have a pin punch or it's too long, I've sacrificed a twist drill smaller in diameter than the motor shaft (usually a number-series drill), cut a piece off the end and used it to with an arbour press. Good idea to hold the piece of drill with a pair of thin-nosed pliers.
Unread 30-01-2012, 23:38
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
I've never tried this method, but using a flame to heat the pinion works for pulling one off or putting one on in this video: http://youtu.be/GDxEK7OUZnE
