Go to Post It's up to veteran teams and mentors to help keep the original spirit of FIRST alive. - It's up to us to make these boards exemplify the FIRST principals in every post. - Ben Mitchell [more]
Unread 23-01-2012, 22:40
xmendude217 xmendude217 is offline
FRC #3851
xmendude217 is an unknown quantity at this point
Re: New Vision sample program
I have a question regarding the sample program, given that we have an image, what's to do with it? How can I begin to translate the image into motor movement?
Unread 25-01-2012, 11:49
dxk3355 dxk3355 is offline
FRC #1126
dxk3355 is an unknown quantity at this point
are there javadocs for the new code?
Unread 25-01-2012, 18:32
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
We base our movement off of center_mass_x_normalized.
Some of the methods involved seem to not be setup for javadocs.
Unread 25-01-2012, 18:44
kamehameHA kamehameHA is offline
Inspector General
AKA: William Ha
FRC #3419 (RoHawks)
kamehameHA is an unknown quantity at this point
Is there a Netbeans plugin update? So far it looks like the CriteriaCollection, which is used in the Java sample code, doesn't exist.
Unread 25-01-2012, 18:57
Turing-complete
The plugin update came at the same time as the new sample.
If your Netbeans isn't set to update every startup/day, go into the Plugins and Reload the updates page.
Unread 29-01-2012, 01:33
sng sng is offline
FRC #0649
sng is an unknown quantity at this point
We're doing something very similar to the sample code (thresholding, convex hull, particle analysis), and finding it takes about a second to process each image on the cRio--far too slow for automated targeting.
Has anyone else been able to get the code to work onboard, with acceptable performance?
Thanks,
Steve (software mentor for team 649)
Unread 29-01-2012, 10:13
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is on a distinguished road
Hi,
We copied the sample code into our project and are using the sample images provided. When we run it we get zero particles found. I added some extra code to print a particle report after every image operation and find that there are particles before the final filter is run(see below).
I also had a question about the following lines:
        cc = new CriteriaCollection();
        cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_WIDTH, 30, 400, false);
        cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_HEIGHT, 40, 400, false);
I read through the vision concepts doc and found descriptions of these criteria. But I was not sure if it meant:
a) crop the entire image to the described rectangle and return particles in the cropped area.
b) only return particles that fit in the size of described rectangle, so search entire image for particles that fit.
Here's the code and output. I am using 10ft2.jpg in this example output. I also tried the other xxft2.jpg images and got the same result, the last filter found zero particles.
            BinaryImage bigObjectsImage = thresholdImage.removeSmallObjects(false, 2);
            printParticleReports("bigobj", bigObjectsImage);
            // fill in occluded rectangles
            BinaryImage convexHullImage = bigObjectsImage.convexHull(false);
            printParticleReports("convexhull", convexHullImage);
            // find filled in rectangles
            BinaryImage filteredImage = convexHullImage.particleFilter(cc);
            printParticleReports("filtered", filteredImage);
The output is jumbled, see this thread: http://www.chiefdelphi.com/forums/sh...d.php?t=101438
[cRIO]
[cRIO] * bigobj******************************************** *
[cRIO] 031250000000000444 , 0.0 )
[cRIO] Area : 301746.0
[cRIO] percent : 98.224609375
[cRIO] Bounding Rect : ( 0 , 0 ) 640*480
[cRIO] Quality : 98.33023755987878
[cRIO]
[cRIO]
[cRIO] Particle(1/2)
[cRIO] Particle Report:
[cRIO] Image Height : 480
[cRIO] Image Width : 640
[cRIO] Center of mass : ( 319 , 240 )
[cRIO] normalized : ( -0.0Particle(2/2)
[cRIO] Center of mass : ( 323 , 31 )
[cRIO] normalized : ( 0.009374999999999911 , -0.8708333333333333 )
[cRIO] Area : 272.0
[cRIO] percent : 0.08854166666666666
[cRIO] Bounding Rect : ( 294 , 29 ) 55*7
[cRIO] Quality : 95.77464788732394
[cRIO]
[cRIO]
[cRIO] 2 146.245212
[cRIO] **********************************************
[cRIO]
[cRIO] 652 )
[cRIO] Area : 307200.0
[cRIO] percent : 100.0
[cRIO] Quality : 100.0
[cRIO]
[cRIO]
[cRIO] Particle(1/1)
[cRIO] Center of mass : ( 319 , 239 )
[cRIO] normalized : ( -0.0031250000000000444 , -0.004166666666666vexhull************************** *******************
[cRIO]
[cRIO] * con1 146.837495
[cRIO]
[cRIO]
[cRIO] * filtered****************************************** ***
[cRIO] 0 147.054589
[cRIO]
Unread 30-01-2012, 20:44
AKA: Maciej
Turns out someone had changed the low R param of the RGB filter (from 25 to 40) while switching between our green light filter and sample's red light filter. I changed it back to 25 and was able to run the sample code in our robot project and find targets. Once that worked we are guessing that the criteria lines add a filter that looks for particles that are in the size range 30,40 to 400,400.
These criteria do not crop an image. If that explanation of the bounding rect width/height is incorrect please let me know.
Unread 18-02-2012, 13:47
dfischer dfischer is offline
FRC #3559
dfischer is an unknown quantity at this point
We are a second year team that is trying at this late stage in the build cycle to do some image analysis. We have a high level question to help us visualize how to make this work. We are using Java.
Where is the best place to do the image analysis? It seems we have a couple of possibilities:
1. Send images from camera to cRio and then run the image analysis code on cRio.
2. Send images from camera to laptop and then run the image analysis code on laptop
3. Send images from camera to cRio and access the images using ftp to laptop and run image analysis on laptop
Are teams using all of these alternatives? Which one is most popular?
Recommendations?
Other alternatives we haven't thought of?
thanks
Dave Fischer - mentor
Jasper Indiana team 3559
