Go to Post I'm still trying to find a way to get FIRST to dump the Chicken Dance song. :p - Koko Ed [more]
Unread 25-01-2012, 20:54
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Setting motor output based on gyro angle
Hello -
Here's the logic behind what I want to do. Note that all of this code is within a while loop inside Periodic Tasks.vi. I want to use the rangefinder and gyro to help one of the drivers shoot.
I want to get the distance from the rangefinder, and if it falls between a certain range, make a case structure true. Within this structure, I can then press button 1 on a joystick to make the next case structure true. Within this next case structure, I'm getting the Gyro angle and seeing if it falls within a range of angles. If it's false, I want to set the motor output of a motor to 0.25 until the angle falls within a range of angles. Download the VI to see what I've drafted.
Do you think this will do what I want it to do?
Thanks.
Unread 25-01-2012, 21:11
FRC #0023 (PNTA)
Rookie Year: 1620
Re: Setting motor output based on gyro angle
New attempt. I think this one is cleaner and is easier to read. See attached VI.
