Go to Post Mr.Lavery You Make My Day - Rohith Surampudi [more]
Unread 25-01-2012, 20:23
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Stop button
Hello -
Last year, we were required to have a stop button wired to our bots. Are we required the same this year?
Thanks.
Unread 25-01-2012, 20:33
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Taylor Hawkins is an unknown quantity at this point
Re: Stop button
Originally Posted by DominickC View Post
Hello -
Thanks.
What stop button are you referring to? The one that is on the driver station? Last year there was the one on the driver station but not on the robot, just the main breaker.
The stop button this year, I believe, is the spacebar on the driver station computer.
Unread 25-01-2012, 20:41
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Stop button
For reference F1 is enable and Enter/Return is now disabled.
Unread 25-01-2012, 21:13
FRC #0023 (PNTA)
Rookie Year: 1620
Re: Stop button
I was talking about the physical button which stopped everything. Guess that answers my question ^^
Unread 25-01-2012, 21:41
nitneylion452's Avatar
AKA: Joe Lee
Re: Stop button
If you are referring to the e-stop button (the USB powered button with a stop sign on it), then your answer is as follows:
Outside of competition, you should have a USB e-stop button connected to your driver station. If, for some reason, you do not have one, you can override the e-stop button by going to the diagnostics tab and double clicking the stop button indicator.
During competition, you will plug in to FMS which will automatically connect an e-stop button that is located at your designated spot.
If you are referring to enable/disable shortcuts, then the above posts are correct.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 25-01-2012, 21:43
FRC #0023 (PNTA)
Rookie Year: 1620
Re: Stop button
Ah yes, the e-stop button is what I'm referring to.
Do I have to write extra code within LabView to work with the FMS's e-stop button?
Unread 25-01-2012, 21:51
AKA: Joe Lee
Re: Stop button
Your driver station will automatically work with the FMS a competition, including the e-stop button. So no need for extra coding.
Joe
Unread 25-01-2012, 22:25
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Stop button
There is no need for a USB e-stop this year outside of competition. The space bar is the e-stop and the enter key is disable.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 25-01-2012, 22:29
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Stop button
No, this is not correct. That was last year. This year, the spacebar is estop, f1 is enable, and enter is disable. However, during competition, there will still be an estop button on the table.
You never "had" to have the estop button connected in previous years, so the only question is whether or not it will work to estop the robot. I don't think it will, but you could reprogram it so that it does. (Tt is a USB keyboard with one button. Change that button from the default to space.)
Unread 25-01-2012, 22:31
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Re: Stop button
In the small parts bag of the kit of parts there are two red stop stickers that go the the space bar of the laptop you are driving with.
Prototype, Prototype, Prototype
Unread 25-01-2012, 22:53
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Re: Stop button
Seconded, this is correct.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 25-01-2012, 22:57
MagiChau's Avatar
AKA: Michael Chau
Re: Stop button
To be more specific the physical USB e-Stop that came in the Kit of Parts meant for driving the robot outside of the main field has been entirely removed from the 2012 driver station software. It has been replaced by a virtual e-Stop button designated as the spacebar when the driverstation is active.
Unread 26-01-2012, 09:32
AKA: Joe Lee
Re: Stop button
Sorry about that everyone. We have been having issues with getting the 2012 software installed so I haven't had the opportunity to see the new software in action. I had assumed, incorrectly, that they didn't change the ds software. Again, I apologize for the poor information.
Joe
