Go to Post You and I have never met, but I am certain that if we went to the same school, we would have been good friends. - Molten [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 25-01-2012, 21:28
JChavis's Avatar
JChavis JChavis is offline
Team 3490's "Pro./Electrician"
FRC #3490 (Vyper Drive)
JChavis is an unknown quantity at this point
Exclamation Long Belt Supply Stores?
Our robot design so far requires single or double sided belts for a CONTINUOUS lift that we are doing this year. That means that we need a SINGLE LONG amount of belt. We can deal with the timer belt pulleys, but does anyone know a source where one could get 250+ in. belts that are like the Gates belts that we received in the KOP this year when referring to the width and teeth?
Hmmm....I wonder if I can create a robot lawnmower with the knowledge I have gained from FRC.....
Unread 25-01-2012, 21:33
AdamHeard's Avatar
Lead Mentor
Re: Long Belt Supply Stores?
Does it have to be a continuous loop? or can it be merely a length of belt with two finite ends?
Unread 25-01-2012, 21:37
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
2826 has really been impressed with SDP-SI (http://www.sdp-si.com/). There hasn't been a belt part/system that we wanted that they did not have. If you call them up (instead of placing an order online), they will give a pretty nice discount when you tell them the order is for educational purposes.
I have only procured 100 inches of continuous, double sided belt from them, but I would bet 250 inches would not be uncommon.
Word of general advice: Stick with the Kevlar reinforced urethane belt if possible. You will thank yourself later
Unread 25-01-2012, 21:38
JChavis's Avatar
Sorry, I did mean a single "strip" length of belt with two ends (no loop)...
Unread 25-01-2012, 21:56
JChavis's Avatar
Arrow Re: Long Belt Supply Stores?
Thank You, but I searched the timer open ended belts in the system with the Kevlar reinforced urethane in the search, and the max length I have seen is 120".
I have a question, though, is the pitch length the actual length of the entire belt, or is that not what you use to tell the length? I'm guessing it is, but I don't like to assume questionable questions......
Unread 26-01-2012, 09:22
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Have you tried McMaster Carr?
http://www.mcmaster.com/#about-belts/=fz23ob
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 26-01-2012, 11:02
JChavis's Avatar
I took a look at the site, and it seems that the maximum length of the type of belt we need is only about 173", which is less than the 250+ that we need....and we need at least two of these belts. I looked at another site with the size we needed, but we came too late. For now (I can't remember the company) they are out.....
Unread 26-01-2012, 11:05
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Have you tried calling Gates? They are a KOP sponsor.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 26-01-2012, 11:08
JChavis's Avatar
We're probably going to call them today at our meeting tonight to see if they have a length not on their online store. The same will probably have to apply to the other options suggested. Its going to be a longer night.....
Unread 26-01-2012, 11:24
AdamHeard's Avatar
Lead Mentor
We've learned a lot about timing belts over this previous summer, and what you want for just about any FRC application is the gates gt2 profile. This is the style from the kop.
The 3mm pitch is fine for smaller applications, the 5mm pitch for big boy stuff.
Gates directly stocks it, as does sdp and various re-sellers.
Data shows it is substantially stronger than the standard MXL and XL you'd get off mcmaster.
Unread 06-02-2012, 12:56
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is online now
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Who has ordered belts & pulleys from Gates? What's the lead time?
Unread 06-02-2012, 13:01
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
All of the free Gates belts from the KOP are 5mm HTD profile belts/sprockets, not GT2.
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-02-2012, 15:10
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
I would also check out Brecoflex, http://www.brecoflex.com they offer a FIRST discount of 30% (I think, my memory is a little fuzzy on the number, but they definitely offer a discount). They are typically very fast with orders, especially for stock parts, so if you give them a call, discuss your application with them and ask what they have available for it. I know that they would easily be able to fill your order, even if they do not have a single length to fit they can weld the belts together to get as long as you would need.
Build first ask questions later.
Unread 06-02-2012, 16:12
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
Thats an uncommon belt length, BUT most belt supply stores or what-have-you will be able to weld custom lengths, call/email them directly and ask
Unread 06-02-2012, 16:20
Bruceb's Avatar
Contact Weimer bearing at
1-800-242-7981
ask for Marty Handle or Mike Kohnle
They should be able to help.
Bruce
