Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 21-01-2012, 20:32
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Arrow Serial port on CRIO-FRC II
We are having trouble opening the RS232 serial port on the new CRIO-FRC II. Using the exact same code, we were able to successfully open the port and use read/writes on the older 8-slot CRIO-FRC version 1. However, with the new 2012 4-slot version we are seeing an error upon initialization:
Using port: ASRL1::INSTR
error code: -1073807246
We have tried the NI serial port VISA module as well as the WPI version, with similar failures. Has anyone else encountered this problem?
Thank you
Unread 21-01-2012, 20:38
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Serial port on CRIO-FRC II
Not really sure what the answer is, but I looked up the error code (you can do that in Help->Explain Error) and got:
Error -1073807246 occurred at an unidentified location
Possible reason(s):
VISA:  (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
Unread 21-01-2012, 20:40
Judging by the error text in the post above, I would guess you need to turn Console Out off with the imaging tool.
Unread 21-01-2012, 20:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Do you have your cRIO imaged properly? Have you started a new project for this year?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 22-01-2012, 21:23
#0368 (Kika Mana)
THanks RufflesRidge! You were right. We used the imaging tool to change the console setting and it worked.
Unread 24-01-2012, 16:45
Tommy.Brown's Avatar
Tommy.Brown Tommy.Brown is offline
Lead Programmer
FRC #1477 (Texas Torque)
Tommy.Brown is an unknown quantity at this point
Question: for connecting a computer to the serial port on the cRIO, does it require a basic serial cord, or a null modem cord?
FRC Team 1477 - Texas Torque
The Woodlands, Texas
Unread 24-01-2012, 18:01
Null Modem. However, I haven't connected to the cRIO serial port recently, because netconsole makes me lazy.
Unread 24-01-2012, 18:48
Lead Programmer
Ok, thank you, we picked up a null modem cable adapter at our local Radio Shack. Does anyone know how to read in values from the serial port on the cRIO? We are using HyperTerminal to emulate a device that will send data to the cRIO via serial port. We know that the HyperTerminal is sending the data, and we know that the data is successfully being transferred down the cable. We are using C++ and we have yet to figure out the logic to reading the values from the buffer with the Read method.
Unread 24-01-2012, 23:30
The console setting for serial out is:
9600
- BAUD
8 - Data Bits
None - Parity
1 - Stop Bit
None - Flow Control
Unread 25-01-2012, 23:31
Lead Programmer
Ok, thank you. After about 5 hours of sitting down and messing around with the serial port code in WindRiver we finally got it working.
Unread 25-01-2012, 23:40
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
9600
- BAUD
8 - Data Bits
None - Parity
1 - Stop Bit
None - Flow Control
9 600 baud over RS-232? I suddenly feel 20 years younger!
Unread 26-01-2012, 13:41
Lead Programmer
9600 baud is just the default value. The cRIO can handle up to roughly 230,000 baud.
