Go to Post the truth is that a 'bot is only as complicated as you make it. - RogerR [more]
Unread 25-01-2012, 11:28
njd231 njd231 is offline
Programmer/Electrician
FRC #4094 (Mars Bandit)
njd231 is an unknown quantity at this point
Power Distrubuter malfuntion?
Yesturday, i had the crio hooked up to the power distributer andit was working fine, a second passed and the crio wasn't powered and i noticed that the crio wasn't on anymore. the power distro. board only showed the 5v LED light on.
Its been two days since then. We thought the the problem was the battery, but it is fully charged now and the power distro is still only showing the 5v LED light being on.
We used a voltmeter and discovered that no power is going to the 12 v and 24v ports. We disconnected everything and tried it; nothing is working.
Does anyone know how to fix this problem?
Unread 25-01-2012, 11:33
Re: Power Distrubuter malfuntion?
What is the voltage of your battery?
Unread 25-01-2012, 12:39
Can you please confirm that the 5V supply still works, but both the 12V and 24V supplies do not?
The three supplies are mostly independent, and only share a common reverse battery protection circuit. From a schematic view, there isn't a single-fault that affects 12 & 24 but not 5. That leaves us with double-faults, which I as a rule don't believe in, or layout faults, which are almost always swarf related.
Did you get some metal shavings in there? Did you short something externally?
Unread 25-01-2012, 19:40
the battery is at 13.6v.
No metal shavings are in it. Its just when I turn it on, only the 5v LED lights up, the 12V and 24V doesn't.
Unread 25-01-2012, 23:55
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
That's kinda high... What is the voltage while the robot is powered up?
We had a battery that caused a similar issue -- two jaguars powered up and the 5v light flickered. I brought out a voltmeter (while the bot was running) and checked the voltage across two WAGO connectors (one ground, one power). It was at about 2.65 volts.
