Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 26-01-2012, 00:30
Re: Labview encoders in autonomous
Originally Posted by jhellr13 View Post
Look, I basically want to be able to drive the robot in autonomous to whatever distance I set the encoder to go. I looked at the example, but that is not really any help.
Have you managed to read the encoder value?
Do you know how to calculate the number of encoder counts that represents the distance you want to travel?
Do you know how to do a comparison function in LabVIEW?
Do you know how to use a Case structure in LabVIEW to do different things based on a value?
The simplest thing to do is to continuously read the encoder and run the robot forward only when the value is less than the distance you want to travel. You'll probably coast past the destination unless you have your speed controllers set to "brake" mode.
Unread 26-01-2012, 13:40
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Alan,
I have not yet managed to read the encoder value because we don't have encoders on our robot from last year, which I'm using to play with programming right now.
I do not currently know how to calculate the number of encoder counts for my distance. I'm pretty i just need to find the converting factor that is usually provided with the encoder or I could find it online.
I'm not exactly sure how to do a comparison function in Labview, though I'm sure I could find it.
I'm pretty good at using case structures to do certain things, though I usually only used them last year for buttons on the joysticks. Not really related to using them for encoders, but I'm pretty sure I could make it happen with case structures.
The way you described that would be the simplest method was exactly how I was thinking it. Find the distance I need and how many counts it would be. Run the encoder and the motors until the encoder hits this value. At that point, I would set the motors to 0/stop. Also, I would set my speed to something like .5 or .7 to lessen the chance of it overshooting my projected distance.
