Re: Long Belt Supply Stores?
Have you tried calling Gates? They are a KOP sponsor.
Bruce |
We're probably going to call them today at our meeting tonight to see if they have a length not on their online store. The same will probably have to apply to the other options suggested. Its going to be a longer night.....
We've learned a lot about timing belts over this previous summer, and what you want for just about any FRC application is the gates gt2 profile. This is the style from the kop.
The 3mm pitch is fine for smaller applications, the 5mm pitch for big boy stuff. Gates directly stocks it, as does sdp and various re-sellers. Data shows it is substantially stronger than the standard MXL and XL you'd get off mcmaster. |
Who has ordered belts & pulleys from Gates? What's the lead time?
My question (only for teams who have done this) is how long did it take to get them? |
#8
All of the free Gates belts from the KOP are 5mm HTD profile belts/sprockets, not GT2.
#9
I would also check out Brecoflex, http://www.brecoflex.com they offer a FIRST discount of 30% (I think, my memory is a little fuzzy on the number, but they definitely offer a discount). They are typically very fast with orders, especially for stock parts, so if you give them a call, discuss your application with them and ask what they have available for it. I know that they would easily be able to fill your order, even if they do not have a single length to fit they can weld the belts together to get as long as you would need.
