Go to Post And to think, a lot of students are planning parties and celebrations on their last day of school and you guys are recycling trash. - JaneYoung [more]
Unread 16-01-2012, 11:31
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Labview encoders in autonomous
Hey all,
I'm planning on using encoders to drive our robot during the autonomous period this year.
This is my second year using labview, and last year autonomous was beyond me, so this year I'm determined.
Can anyone help me with some diagrams/pictures of how to set up encoders for autonomous and get them working?
Thanks a lot!
Unread 16-01-2012, 11:42
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Labview encoders in autonomous
i don't know much about encoders, but i know that autonomous is almost exactly like teleop, except for instead of using joysticks to drive, you have the code input numbers
Unread 17-01-2012, 08:15
The Encoder Example project in LabVIEW should tell you everything you need to know in order to connect, initialize, and read from the type of encoder provided in the Kit of Parts.
In the main LabVIEW FRC 2011 "getting started" window, click the Support tab then click the Find FRC Examples... option. You will find Encoder Example.lvproj under the Sensors subfolder of the FRC Robotics folder.
Unread 25-01-2012, 15:24
frankthelyon frankthelyon is offline
FRC #2557
frankthelyon is an unknown quantity at this point
I am also trying to get encoders working in Labview. How can I set a motor output value using encoders? For example, arcade drive> output value > encoder?
Unread 25-01-2012, 22:11
If you can be a little more specific about what you want to do, we might be able to give you some advice on how to do it.
Unread 25-01-2012, 22:17
FRC #4272
I would still like a more helpful answer to my initial question. Look, I basically want to be able to drive the robot in autonomous to whatever distance I set the encoder to go. I looked at the example, but that is not really any help. Do I need to do a PID Loop for this, or is there a block of code that I can use that I can link to my drive code to drive it a certain distance in autonomous?
Help?
Unread 26-01-2012, 00:30
Have you managed to read the encoder value?
Do you know how to calculate the number of encoder counts that represents the distance you want to travel?
Do you know how to do a comparison function in LabVIEW?
Do you know how to use a Case structure in LabVIEW to do different things based on a value?
The simplest thing to do is to continuously read the encoder and run the robot forward only when the value is less than the distance you want to travel. You'll probably coast past the destination unless you have your speed controllers set to "brake" mode.
Unread 26-01-2012, 13:40
FRC #4272
Alan,
I have not yet managed to read the encoder value because we don't have encoders on our robot from last year, which I'm using to play with programming right now.
I do not currently know how to calculate the number of encoder counts for my distance. I'm pretty i just need to find the converting factor that is usually provided with the encoder or I could find it online.
I'm not exactly sure how to do a comparison function in Labview, though I'm sure I could find it.
I'm pretty good at using case structures to do certain things, though I usually only used them last year for buttons on the joysticks. Not really related to using them for encoders, but I'm pretty sure I could make it happen with case structures.
The way you described that would be the simplest method was exactly how I was thinking it. Find the distance I need and how many counts it would be. Run the encoder and the motors until the encoder hits this value. At that point, I would set the motors to 0/stop. Also, I would set my speed to something like .5 or .7 to lessen the chance of it overshooting my projected distance.
