Go to Post Even then, the robotics competiton is only part of FIRST. - Billfred [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 26-01-2012, 13:58
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
Re: CAN troubles with Black Jaguars
Checked last night and no such luck. All look Jaguar connectors look fine to me. We also tested that the end to end termination was reading the correct resistance. So back to the same issue we had last year with CAN: Intermittent timeout of messages, with no clear cut root cause or solution.
One experiment that I will be running tonight is the use of sync groups. My code makes extensive use of sync groups for updating any motors that are linked together, I doubt that it's involved with my problem but I'll grasp at any straw at this point.
Unfortunately, looking at the forums CAN issues seem to be just as rampant this year You'd think we'd learn our lesson.
