Go to Post So measure not by the masses, but by the sparks that you generate. - Kims Robot [more]
Unread 24-01-2012, 18:17
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Top/bottom roller shooter vs. bottom roller only
We have been heading toward a shooter that has spinning wheels on both the bottom and top side of the ball. By setting the speeds differently, we can get a desired amount of backspin.
But I'm thinking that in addition to backspin influences, this will also influence angle of exit from the apparatus. I know some designs have only a bottom spinning wheel and use a non-moving hood on the top side (except for possibly angle adjustment) I'm thinking this will result in a more reliable, consistent shot, even though it may not go as far, and the backspin RPMs will increase along with the velocity, vs. being able to independently control speed and backspin with wheels top & bottom.
Thoughts?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 24-01-2012, 20:25
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Top/bottom roller shooter vs. bottom roller only
With one driven wheel at 1500 RPM, you get the same exit velocity as with two driven wheels at 750 RPM. So I am leaning towards the two driven wheel solution.
I am thinking that two FP motors driving one wheel is the same energy into the ball as one FP driving each wheel. Yes, you should manage your spin as well.
So if there's a vote, I pick the 2 roller shooter.
Unread 24-01-2012, 20:45
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Not necessarily true. In the fly wheel designs very little of the force is in fact transmitted directly to the balls from the motors. Just look at the torque and how fast that ball gets moving in a short period of time...it just wouldn't make sense. What it really is, is a conservation of momentum. The angular momentum of the wheels is translated to linear and angular momentum of the ball. Therefore, all that matters in terms of how fast the ball goes is the CHANGE in angular momentum of the wheels. A bigger decrease means a faster release. Simply adding another motor to the axle of the wheel at the same reduction will not cause a faster release because the free speed would remain the same. However, what it would do is cut in half the time it takes for the flywheel to get back to full speed because the torque output of the motors doubles. If you want a faster release, you would need to reduce your reduction on the motors, increasing the free speed of the fly wheel and increasing the change in angular momentum of the wheel.
However if you put the motors on separate wheels, then you will get a greater decrease in angular momentum of the wheels because there are now twice as many wheels transferring momentum to the ball. Then you wouldn't have to adjust the reductions and you would increase the release speed. (However, your reload speed would remain the same....trade offs!)
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 24-01-2012, 20:56
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
We started with a 4 wheel pitcher (like the early ones in videos here), it ran on 2 CIMs while we were waiting for the AM FP gear motors. Each axle had 2 narrow wheels.
Based on some further discussions we prototyped a single wheel, 1 motor design, as seen in other videos.
Real world results - we have found simple is better and we are going that route (hint hint). We get a really nice trajectory and consistent backspin. The key seems to be in tuning the angle and length of the box 'lid'. And consistent ball insertion.
One thing we found in quick testing is that the 4 wheel method was a lot more touchy, if the ball didn't contact all 4 wheels smoothly and at the same time it created erratic shots.
Either design will work and I am sure we will see plenty of both, but a single bottom wheel looks good to us.
Unread 25-01-2012, 07:06
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
I think the initial velocity of the ball is a function of the rotational velocity at the edge of the wheel. Wouldn't your 2-wheel example just produce 2X torque (if driven at the same speed) rather than 2X initial velocity of the ball? I must be missing something...
Our students built a 2-wheel prototype (both on the bottom) that is pretty consistent and decided not to look at a 2-wheel (top & bottom) shooter.
Unread 25-01-2012, 07:50
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
John V.,
Our prototyping experience supports your statements regarding shot to shot consistency.
For any particular motor selected to power your wheeled shooter, you can choose a gear ratio to get your desired shot speed. A single wheeled shooter needs to spin ~2X as fast as a double wheeled shooter. A speed difference between your double wheels, either with speed controlled motors on each wheel, or mechanical coupling, gives a selectable amount of backspin. A single wheeled shooter is slightly less "efficient" in that much more energy is expended putting a higher, non-selectable, amount of backspin on the ball.
Energy transfer happens nearly instantaneously, and is governed by the equations derived in a different thread. The most important factors affecting ball speed are rotational speed of the wheels and their rotational moment of inertia. Motor power has little effect on the shot itself. Rather, the more motor power, the faster the initial spin-up of the wheels, and the shorter the time between shots.
The majority of the time, the motor runs at nearly its free speed, inhibited only by the energy losses in the power transmission mechanics. The reduction in speed after a shot takes the motor closer to its max power speed. This helps the motor power the wheels back up to their full free speed. The higher the rotational inertia of the wheels, the less reduction in speed during a shot.
We found that our single wheeled prototype was more consistent, shot-to-shot, than our double wheeled prototype. Both types of wheeled shooters depend on ball friction and compliance for ball speed. The balls vary in both of these aspects right out of the bag. We expect these variations to only get worse over time. So, there is going to be a limit to the ball to ball repeatability of wheeled shooters that is out of our control. We also expect that the accuracy of a wheeled shooter will decrease over time, as the balls degrade.
A well executed catapult should be less subject to ball to ball variation as long as the shape and mass of the ball is consistent. Our catapult prototype keeps being "almost there". So, we have decided to go with a single wheeled shooter as our "plan of record" and proceed full speed ahead with detailed design and fab. At the same time, we are letting a couple people finish the catapult in case it proves to be a revolutionary breakthrough in terms of repeatability.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 25-01-2012, 08:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I vote for two-roller (NOT two-wheel) option as well for the reasons Don highlighted.
I think that rollers are more tolerant to ball variances than wheels are because they're wider (either in feed, density, compressibility, etc). Our two-roller shooter this year (and in 2006) was VERY consistent, to within less than a ball radius over 20-30ish shots in our short-range prototype being fed by hand (i.e. inconsistent feed) with 6 different balls.
My $0.02
Unread 26-01-2012, 10:50
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
My $0.02
What diameter roller and how much compression? We are looking at a hybrid with 1.75" roller and 1.5" compression. I am worried that we need to have more compression or risk the dreaded orange snow.
Unread 26-01-2012, 10:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Our tests were done with 1.5" rollers running about 1.5" of compression. No-slip carpet material is a good roller wrap.
Unread 26-01-2012, 11:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I've seen how challenging it is to make one wheel spin with controlled speed....I have little desire to double our workload.
Unread 26-01-2012, 11:38
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Greetings,
I will have to agree with Todd on this one. A one axil shooter has been much more consistant than the 2 axis shooters we prototyped. We found that two
8" AM wheels roughly 2-3 inches apart running at 3500 RPM will shoot 1/2 court with a success rate ~40% with a rough prototype and hand feeding. We think we could get that up to 60%. As Todd stated before, the variation of the balls will make consistant long shot extremely difficult.
Unread 26-01-2012, 14:18
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
Interestingly enough, we prototyped both 1 and 2 wheel shooters and got exactly the same error with both (about 0.4" for every foot of distance). However, the two wheeled design shot much farther, as would be expected. The advantage of a one wheel design is that it gives wickid backspin and we found that this gave a higher shot percentage (with the same overall shot error) because balls that hit the backboard tended to shoot down into the hoop.
Our team went with the one wheel design. We agreed, though, that either could be made to work. We also agreed that a catapult would be immune to the ball error, which I discussed our attempts to quantify in another thread (squishimetrics).
The most interesting test was last night when the local police brought a radar gun over to test our shot speed. After adding aluminum foil to reflect the radar, we found that our shots were coming out at about half of the theoretical value. We, therefore, need to really investigate the energy transfer efficiency at different speeds, and its likely not a linear relationship.
Jim Browne, EIT
Team 1058 - PVC Pirates
Unread 26-01-2012, 14:50
wilsonmw04's Avatar
Coach
That's the disadvantage to the wicked backspin. The impulse given to the ball is split between angular and linear momentum. The more backspin, the less forward velocity we will see off our shooter.
Unread 26-01-2012, 14:52
Aur0r4's Avatar
Engineering Mentor
AKA: Jim Browne
Exactly... That, and we can hear that there is some degree of slippage on ours. There is also energy loss in compressing the foam, deforming the device, etc...
Jim Browne, EIT
Unread 26-01-2012, 14:53
MrForbes's Avatar
AKA: Jim
You need to have some wicked rpm on a single wheel to get good distance with it, but imo having the ball bounce off the backboard, into the basket, is worth it
