Go to Post I would suggest spending a few more hours digesting the manual before you finalize your designs. You seem to have missed a few key rules. - GaryVoshol [more]
Unread 26-01-2012, 16:36
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Re: Probes (and some other aspects) not working
Ah, there is one more thing I failed to mention.
If you turn on "Retain Wire Values" before running the VI, then everything appears to work perfectly (all probes work). However, if you start with "Retain Wire Values" off and then turn it on during execution, you still see "Not Executed."
