Go to Post My robotics team is my love (my ex-wife told me so). - Koko Ed [more]
Unread 25-01-2012, 15:11
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Camera works, but not.
Hey guys-
So we are using a brand new Axis M1011 camera. I followed the setup according to the getting started guide, and used the Axis Camera Setup tool.
I connected it to the bridge, and I get the camera image in the Dashboard just fine. However, once I enable the robot, the camera image changes to all black. It still has power, and the cable is still firmly connected. The only way to get the image back is to manually reset the camera (press the reset button) and reassign the IP address.
Any idea how to fix this?
Is it possible we have a deadish camera?
Edit: When the image is all black, I can still ping the camera using command prompt (10.17.71.11) and it works just fine.
Unread 25-01-2012, 15:19
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Camera works, but not.
Check out the Utilities Update v2.0 http://joule.ni.com/nidu/cds/view/p/id/2262
Fixes in 2.0
cRIO Imaging Tool - Timeout error due to various network interface configurations
Setup Axis Camera Tool - Axis 206 camera loses communication after power cycle
I know this fix is for the Axis 206 but will this apply to the Axis M1011 Camera as well? Looks to me (as far as I know) it's the same issue.
Unread 25-01-2012, 16:58
AKA: Matt B
FRC #1771 (1771)
Hm, I'll definitely try it tomorrow.
Thanks!
Unread 25-01-2012, 20:34
gr8dragon's Avatar
gr8dragon gr8dragon is offline
AKA: Parth Patel
gr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of light
Hey, I am not sure if you are using C++ but that is what we are using, and the example vision code in windriver sets the brightness to 0. That maybe your problem.
FRC 2013 World Champions 1241 (1477, 610) Thank you Team 1241 for letting me be a part of your wonderful team.
FRC 2010 GTR Regional Chairmans (188)
FRC 2009 Finger Lakes Regional Champions 188 (1507, 174)
Unread 25-01-2012, 21:10
Good point about the Brightness. The values seem to be camera dependent, and I noticed that zero was far darker on one than on the other. I think the M1011 was very dark with a zero.
Greg McKaskle
Unread 26-01-2012, 16:42
AKA: Matt B
FRC #1771 (1771)
Yup, turns out it was the brightness. We are using C++.
I set the value to 50, and it still went straight to black. Set the value to 100 and it went pure white.
For now I just removed that line, and everything works peachy!
Thanks for the help.
