Go to Post "This is the year that everyone on CD is going to learn to spell." "This is the year that everyone on CD will make a serious effort to write grammatically correct sentences." "This is the year that everyone on CD will think BEFORE they post." ... nah. - dlavery [more]
Unread 25-01-2012, 13:21
Cheeset2 Cheeset2 is offline
FRC #4254
Cheeset2 is an unknown quantity at this point
Smile Help?-Vex pro Spike Switch?
Dear Interwebs,
This is team 4254. This is our rookie year and we need a little help with programming. We have a two person programming team and we both know java from high school courses. We have our robot driving around but we are having difficulties programming the Vex Pro Spike switch. Please help us!
Thank you.
Unread 25-01-2012, 16:21
FRC #4254
Re: Help?-Vex pro Spike Switch?
I realize that i gave no info about our problem, but we really have nothing done. We have tried many things but none of them have worked and i think if we just saw an example of code that worked it would help us out a boat load
Unread 26-01-2012, 10:20
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Import the Relay class
import edu.wpi.first.wpilibj.Relay;
Create a Relay object (I'll call mine Tom)
Relay Tom = new Relay(PORT YOU PLUGGED THE PWM WIRE INTO ON DSC);
The code to turn the spike on is something like
Tom.set(Relay.Value.kForward);
I'm not at a computer with the SDK but I'll check with the JavaDocs to make sure this is correct in a moment.
Edit: After a quick check this seems correct. To disable the relay, use this:
Tom.set(Relay.Value.kOff);
Unread 26-01-2012, 11:28
FRC #4254
Thank you very much. We will be sure to try that when we get our connection to the robot back....
Unread 26-01-2012, 14:11
FRC #4254
Can you please explain this part of your code in more detail?
Specifically the PORT YOU PLUGGED THE PWM WIRE INTO ON DSC part.
Unread 26-01-2012, 17:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
There are 8 relay ports on the sidecar. They are numbered from 1-8. The number corresponding to the port you plugged the PWM cable from the relay into the sidecar replaces the "PORT YOU PLUGGED THE PWM WIRE INTO ON DSC" in the code.
The rest of the code just initializes the relay using the port. Everything is an object.
Unread 26-01-2012, 23:21
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
The ones in red are the relay ports
http://team2168.org
