Go to Post We are not here to build robots, or to win a contest, or to travel to cool places or to bring home trophies. we are here to see what a career in engineering and science is like; anything else that happens along the way is frosting on the cake - KenWittlief [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 26-01-2012, 18:41
hannigan hannigan is offline
FRC #2264
hannigan is an unknown quantity at this point
CAN db9 adapter wiring
Hello,
Could anyone explain which wires from the db9 adapter are connected to the serial cable that goes to the Black Jaguar. Also, how are the colors arranged in the 6p6c connector. We are using the db9 connector from the 2012 kit of parts, which I think is different from a generic one from online.
Thanks
Unread 26-01-2012, 22:54
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: CAN db9 adapter wiring
This guide should cover pretty much everything, I'm uploading a follow up video to youtube now that should be up in 1/2hr to illustrate some of the wiring better.
team2168.org/index.php/resources/electrical/210-can-jaguars
http://team2168.org
Unread 08-02-2012, 11:02
MattKahn MattKahn is offline
FRC #0157
MattKahn is an unknown quantity at this point
One thing to be aware of, our team ran into issues with a DB9-6P6C adapter in which the color coded wires from the 6P6C side did not match the docuementation. If you're having trouble with the adapter and serial connection, ignore the color coding and check that the pins are correctly connected to each other...
Unread 10-02-2012, 02:55
otherguy's Avatar
sparkE
AKA: James
Agreed. I actually mention this in the video linked above.
http://team2168.org
Unread 10-02-2012, 14:59
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
We made our serial Jaguar cable slightly differently. Instead of inserting the terminating resistor into the plastic RJ-12 plug, we put the resistor into the DB9 serial connector. We used the red and green wires that you taped up and insulated. Instead, we stuck the terminating resistors into female pins of the red and green wires (pin 3 and 4) and soldered them to prevent them from coming out. Put heat shrink tube on both pins so they don't short anything else. Stuck all the wires including the resistor back into the DB9 shell and done.
Unread 11-02-2012, 15:19
otherguy's Avatar
sparkE
AKA: James
Our team uses 4 conductor wire across the board, so this wouldn't work in our case. You would need to have 6 conductor wire from the DB9 adapter to the Jaguar (which is probably what you are using).
http://team2168.org
Unread 13-02-2012, 06:33
mikets's Avatar
Software Engineer
The KOP supplies the DB9 connector and the 6-conductor cable, so it's not something I need to get specifically.
