Go to Post I never wanted to be a teacher. This was the year I learned that I am one. It turns out mentors are teachers. Oops. - marshall [more]
Unread 23-01-2012, 20:09
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
can i get some help understanding PID
So my team is thinking about transferring to CAN for our Jaguars and I don't understand the PID loops can I get some help please
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 23-01-2012, 21:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: can i get some help understanding PID
You can search ChiefDelphi.
Like this thread, or this thread, and there's even a paper called "PID without a PhD" you might look for ...
Unread 24-01-2012, 12:25
inkspell4's Avatar
What Values have you found to work the best
Unread 24-01-2012, 12:38
Joining the 900 Meme Team
FRC #0079
4
That is dependent on the system you are controlling. Play with some values and see what works best for you.
Unread 24-01-2012, 12:55
inkspell4's Avatar
For Which P,I, or D.
We are using jaguars to control cim motors and also how might you hook up a encoder directly into the jaguar for use with the pid loop
Unread 26-01-2012, 17:52
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
I think you're assuming that the PID values control only the motor output. In reality, these values are used to control an entire system. One person's kitbot transmission may be different from someone else's which would mean that their values will be different. You have to sit down and tune your robot to how you think it responds better.
The P, I and D will all cause the robot to behave differently. I can recommend as a general rule of thumb to try a value < 1 for I and something around 20~30 for P (I'm not exactly sure on this value). Leave the D at 0 until you tune these.
You should definitely read the document mentioned above in order to understand what each value does to the system. Only then will you be able to see what it does and how it reacts.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 26-01-2012, 18:52
See attachments.
ID:	11588  Click image for larger version
Unread 27-01-2012, 10:46
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
Ether is correct, that's exactly how we've been connecting our encoders for years! Also, keep in mind that if you want to use the built in PID features of the JAGs, you're going to have to implement the CAN Bus. You won't be able to use PWM anymore.
Unread 28-01-2012, 15:08
mbushroe mbushroe is offline
FRC #2840
mbushroe is an unknown quantity at this point
HOW do we control the Jaguar digitally from the cRIO? I am still looking for the C++ API that will allow us to use the serial interface to format and send commands to the Jaguar, and read the status data sent back.
Mike
Unread 28-01-2012, 23:07
Look into the CANJaguar class.
