Go to Post Is there anything more inspiring than inspiration? The answer is no; there is not. - Jared Russell [more]
Unread 26-01-2012, 19:53
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Gryo Setup
Originally Posted by compwiztobe View Post
If you want to try and balance this way I would suggest using the accelerometer since this will give you an absolute "heading" of sorts
The accelerometer doesn't give you "absolute heading", it gives you the G force that was applied to each axis. It's perfect for detecting tilt using the Z-axis because if you are flat on the ground, the Z-axis will read 1 G. But if you are tilted then by applying physics to split the G force vector into two vectors (one perpendicular to the accelerometer: the Z-axis, another parallel to the surface of the accelerometer), you can see the Z-axis will have a value smaller than 1 G. The more it is tilted, the smaller the Z-axis value). So to determine the tilt angle, you can do an arccosine to the Z value.
