Go to Post Think of the build season as kiddie bowling. Mentors should be the bumpers and your mom who lines you up and gives you advice. - Joe Matt [more]
Unread 26-01-2012, 21:01
JChavis's Avatar
JChavis JChavis is offline
Team 3490's "Pro./Electrician"
FRC #3490 (Vyper Drive)
JChavis is an unknown quantity at this point
Re: HELP! LAPTOP WON'T SHOW ANYTHING!!!!!
Here's the thing, the laptop doesn't turn boot at ALL, it just turns on the power lights, runs the fan for about 7 sec, then the fan just goes out with the lights still on, no other noise....I just can't figure out what or how it went wrong. I would like to take it apart but I just don't know where to start or if I need to take it apart. It worked again from this same problem before by me holding down the keys and then turning it on, but not even that now will work.
I will try what you stated, but how should I do this exactly?
Our team has the E11 type, if that helps....
Hmmm....I wonder if I can create a robot lawnmower with the knowledge I have gained from FRC.....
Unread 26-01-2012, 22:07
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Ok, that kinda rules out the "broken screen" issue... I still recommend putting it's hard drive in another computer. Teardown video: here
Unread 26-01-2012, 22:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A bad SSD hard drive will result in a no-boot, but you should still see the bios load and classmate splash screen. It almost sounds like your screen or the cable connecting your screen has gone bad. Or, you may have lost your motherboard.
On the off chance that it may be a memory issue, you may want to open the memory compartment and reseat the memory modules. Most computers I've worked on will give an audible beeping alarm when the memory is not in correctly, but who knows.
After that, I would contact the company that makes classmates - they have a service number. I believe you can find more info on the classmate on the FIRST website.
In the mean time, remove the hard-drive from the computer and hook it up to another to see if you can read the data, as the first poster suggested.
Unread 27-01-2012, 06:58
Dusk Star's Avatar
AKA: Andrew
A teardown video, to show how to get at the memory, hard drive, etc. is here:
http://www.youtube.com/watch?v=pCvm5KS9k-s
Good Luck!
Unread 27-01-2012, 21:07
JChavis's Avatar
Thank You both for your suggestions!
I figured out that the connection between the hard drive and the motherboard was being prevented by a wire that powers the realtek graphics system. Whenever the covers are placed over the electronics, the wire adds pressure to the SATA convertor connector, causing it to not get a proper connection. I believe a cause to this was the loose wire that somehow loosened up even more in the wrong place. The RAM Stick wasn't damaged, and the Hard Drive wasn't damaged (WHEW!!!).
Again, thanks!!!!
If I can, I may be able to post a video of what I did to help others who may have this problem...
The video this time will be for the E11 Classmate, as I had to figure out how to take it apart, for the video posted did help, but it was for a past version of it.
Unread 04-02-2012, 13:12
TeleportSandwic's Avatar
TeleportSandwic TeleportSandwic is offline
FRC #3490
TeleportSandwic is an unknown quantity at this point
You should post a link to whatever video you make.
P.S If you are reading this, the laptop broke again, so this might not be a permanent fix.
Unread 04-02-2012, 18:06
JChavis's Avatar
Well, it seems that our laptop again won't function properly. I still think it is the connector from the hard drive to the motherboard, or even the RAM stick inside the computer. Is there any type of special service that FRC teams can use for laptops? I already Reseated the RAM stick and the Hard Drive several times, so I can't tell what the problem is for this computer.....
With all of these problems going on, we were able to hook up our hard drive to one of our school computers and boot it off of the hard drive, which worked perfectly. This still furthers my theory of the yellow laptop connector being the problem between the hard drive and the motherboard. I just hope that FRC teams can get their classmates serviced......
Oh, and if you are reading this Nick, we got the robot driving and turning!!! We just need to fix the programming to be able to get the back two wheels turning tomorrow!
Unread 04-02-2012, 23:06
Dusk Star's Avatar
AKA: Andrew
One thing I might recommend for getting your back wheels to work is to just use a pwm splitter to run both jags off of one signal. That way, you can ensure that each side is operating in sync, without extra work for the programmers.
Unread 05-02-2012, 11:38
JChavis's Avatar
Yep, that was the exact thought I had in mind. It's just exciting to see that our robot chassis looks formidable....
