Go to Post "Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." - Albert Einstein - Edward Debler [more]
Unread 26-01-2012, 21:29
Re: NI Software for FRC 2012
The one idea I can throw out is to try copying the installer files to your hard drive then installing from there. Beyond that it would probably be helpful to know what the error(s) are that you are getting.
Unread 26-01-2012, 21:32
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
We got a bad NI flash drive.
So we went down the street to another team and just copied another teams good NI flash drive to a portable hard drive.
Is there a team in your area that you can ping ?
Ed Barker
Unread 26-01-2012, 22:17
nitneylion452's Avatar
AKA: Joe Lee
The errors we are getting are something along the lines of a file not being found or not properly installing. We meet again on Saturday morning. I'll post a screen shot of the error then.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 27-01-2012, 14:02
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
We had a similar problem. The heat of the laptop causes the usb key to change form making the internal contacts separate.
We squeezed the usb key, inserted it into the laptop and held it with fingers while
someone made a copy of all the files. It takes about 5 minutes to copy all the files.
