Re: FRC WiFi Radio 2012 splicing
Be very careful when you do this and make sure you wire the adapter properly to the DC converter. Doing it wrong will fry the radio.
Check the polarity of the adapter so you know which wire on the snipped connector needs to be wired to the positive wire from the converter and which goes to the negative. Double check your polarity with a meter. |
