Go to Post For guys, is the appropriate term "manpris". ? - Chris Fultz [more]
Unread 26-01-2012, 16:18
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
2 switches to connect to USB cable.
I have cutted a USB cable and I want to be able to know when I close the circuit of each one of the switches.
thanks for helping,
Neat-Team #1943
Unread 26-01-2012, 16:30
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Re: 2 switches to connect to USB cable.
If you are just planning on plugging in the usb cable to a computer, this won't work. Those wires aren't digital input, they only talk USB protocol.
You need to use the FirstTouch to get digital inputs via USB to the driver station.
Unread 26-01-2012, 16:51
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
thanks for helping,
Neat-Team #1943
What exactly are you trying to do? USB cable has nothing to do with switches. USB cable is used to connect your laptop to a USB device. If you are talking about some switches such as the "Emergency Stop" button from last year, it is not a simple switch. It is a USB HID button device.
Unread 26-01-2012, 20:55
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The CCI from eStop Robotics is another alternative to receive digital inputs.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 26-01-2012, 22:51
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The Driver Station software is designed to talk to the First Touch module which has custom firmware on it.
Unread 26-01-2012, 23:08
slijin's Avatar
Pockets
AKA: Samuel Lijin
The CCI is custom designed to serve as a simpler alternative to the FirstTouch. The Driver Station isn't designed to talk to the FirstTouch, but rather viceversa, hence the custom firmware that you noted.
Unread 29-01-2012, 17:49
Neat,
Have you confused USB with PWM? I suspect you have. If you are using the PWM cable to connect to a digital input on the Digital Side Car, then connect one side of the switch to the black wire of the PWM and the other side of the switch to the white wire. Insulate the red wire so it will not touch anything as it is connected to 5 volts. The switch when open will present a 'high' to the side car and when closed will present a 'low'.
