Go to Post Does that mean that the Ultimate Question of Life, the Universe, and Everything is, "How many total tubes will be available to score for the FRC 2011 game, LogoMotion? - EricH [more]
Unread 26-01-2012, 23:38
ianonavy ianonavy is offline
Programming Mentor/Alumnus
AKA: Ian Adam Naval
FRC #3120 (RoboKnights)
ianonavy is an unknown quantity at this point
Re: A good time based way to program
Originally Posted by neal View Post
I can't test that either until Saturday, but wouldn't that delay the whole main operatorControl() while loop?
Oh, I see. You're using the SimpleRobot class. I recommend that you really look into the command-based robot implementation. It makes everything a lot more object-oriented, and it's really nice. There should be a sample project called GearsBot if you've updated your NetBeans FRC plugins for this year's competition.
If you are going to stick with that style, you could try something like this
// Buttons
        final int MOVE_ARM = 1;
        // Constants
        final int ARM_PWM = 1;
        final double ARM_SPEED = 1.0;
        final int ARM_TIME = 1.0; // seconds
        // Should be instance fields
        Timer armTimer = new Timer();
        Jaguar arm = new Jaguar(ARM_PWM);
        Joystick joystick = new Joystick(1);
        armTimer.reset();
        armTimer.stop();
        while (isOperatorControl() && isEnabled()) {
            if (joystick.rawButton(MOVE_ARM)) {
                armTimer.start();
            if (armTimer.get() / 1e6 < ARM_TIME) {
                arm.set(ARM_SPEED);
            } else {
                arm.set(0);
                armTimer.stop();
                armTimer.reset();
I don't know that it's the best way of approaching it. There's probably some better way of putting them into separate functions. Essentially, you're going to have separate Timer objects for each motor. You could extend the Jaguar class and make something like a TimedJaguar.
Undocumented and untested quick example:
public class TimedJaguar extends Jaguar{
    Timer timer;
    public TimedJaguar() {
        timer = new Timer();
        timer.reset();
    public void setForTime(double power, double time) {
        // Implement here.
