Go to Post Curse those filthy wrench-swinging rivet-popping screw-driving hammer-smashing mechanical barbarians. Hand over the robot to the programmers! - cjl2625 [more]
Unread 26-01-2012, 23:36
Glen Glen is offline
FRC #1444
Glen is an unknown quantity at this point
How to capture image from Axis 206 and save to cRIO?
Hi, I am a beginner programmer for Team 1444, and we are trying to capture an image from the Axis camera and then save it to the cRIO. I have seen some other posts around, but looking through the FIRST documentation, we can't seem to figure out how that would work. We have the live video streaming correctly to the driver station, and we are using c++. We don't care where the image is saved to (the home directory is fine). Would anyone be able to provide some advice and/or a code example which would be much appreciated?
By the way, we directly took the code from FIRST's WPILib Guide for the 2012 Vision System, and it seems like this line is what saves the image, but we never find the image in the cRIO's file system(ftp://10.14.44.2):
HSLImage *targetImage = new HSLImage("/testImage.png"); // create image
I am unsure as to what this is supposed to be doing, but it looks like this should save the image , right? What could be wrong?
Unread 26-01-2012, 23:40
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: How to capture image from Axis 206 and save to cRIO?
This line attempts to open an image at that location, not save it. See here, http://mmrambotics.ca/wpilib/class_h...8e2dd2 4383e6
You can use the ImageBase::Write function...
HSLImage *image = camera.GetImage();
image->Write("testImage.jpg");
Unread 26-01-2012, 23:54
FRC #1444
Awesome, I'll have to try that out tomorrow. I'll report back if it works! And I suppose that this will save it in the root directory?
Unread 27-01-2012, 17:26
Tommy.Brown's Avatar
Tommy.Brown Tommy.Brown is offline
Lead Programmer
FRC #1477 (Texas Torque)
Tommy.Brown is an unknown quantity at this point
In nivision.h in WPILib there also exists several methods, such as imaqWriteBMP, that will save the picture in various different formats to the cRIO.
FRC Team 1477 - Texas Torque
The Woodlands, Texas
Unread 29-01-2012, 13:27
pentrium pentrium is offline
FRC #1075
pentrium is an unknown quantity at this point
@Basicxman, do you know where the image is saved?
Unread 29-01-2012, 13:34
Emily Horsman
Should be saved in the root directory, you can open a browser or Windows Explorer and go to
ftp://10.te.am.2
Unread 29-01-2012, 15:59
FRC #1075
We keep on getting an Imaq image writeFile error in the driver station and the image doesn't show up in the root folder frt://10.10.75.2, do you have any suggestions on how we can solve this problem?
Unread 29-01-2012, 17:35
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Try Java, seems to work in there.
Unread 30-01-2012, 14:14
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
I would suggest that you verify a few things. The write-error could be caused by something going wrong prior (upline)...
Are you able to do printf() or use the driver station LCD or SmartDashboard in order to get printouts? If so, then you need to verify a few things
AxisCamera* pCamera = AxisCamera::GetInstance();
if (pCamera)
  ColorImage* pImage = pCamera->GetImage();
  if (pImage)
    if (pImage->GetHeight() == 0 || pImage->GetWidth()==0)
      printf("Error with image size - height/width is zero.\n");
    else
      pImage->Write("Image.jpg");
      printf("Wrote file out to Image.jpg...should be a success.\n");
    delete pImage;
  else
    printf("Image returned by GetImage was NULL. Big error.\n");
else
  printf("Never got the camera instance. Big error.\n");
If this runs and says "Wrote file out...." then goto your browser when the robot is in DISABLED mode via ftp://10.te.am.2 and click (hopefully) on Image.jpg and see it.
Let me know where you encounter errors in this process and we'll go from there.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 31-01-2012, 16:17
mathgeek01 mathgeek01 is offline
C++ Ninja in Training
FRC #3397 (Robolions)
mathgeek01 is an unknown quantity at this point
I am having a similar problem to the OP. I'm using the below code, a modified version of what bob.wolff68 suggested. Running this function once at the beginning of teleop, I get the image size error on the DS LCD every time. Does anyone know what could be causing this behavior?
void CameraTest()
		AxisCamera& pCamera = AxisCamera::GetInstance();
		pCamera.WriteResolution(AxisCamera::kResolution_320x240);
		pCamera.WriteCompression(20);
		pCamera.WriteBrightness(0);
		if (true/*pCamera*/) //since pCamera is not a pointer, this wouldn't work...
		  ColorImage* pImage = pCamera.GetImage();
		  if (pImage)
		      dslcd->PrintfLine(dslcd->kUser_Line4,"Error with image size - height/width is zero.");
		      dslcd->UpdateLCD();
		    else
		      dslcd->PrintfLine(dslcd->kUser_Line4,"Wrote file out to Image.jpg...should be a success.");
		      dslcd->UpdateLCD();
		    delete pImage;
		  else
			dslcd->PrintfLine(dslcd->kUser_Line4,"Image returned by GetImage was NULL. Big error.");
			dslcd->UpdateLCD();
		else
			dslcd->PrintfLine(dslcd->kUser_Line4,"Never got the camera instance. Big error.");
			dslcd->UpdateLCD();
Daniel
Unread 01-02-2012, 14:48
FRC #1075
I received an error for having no dimensions when I tested the code, is there a reason for this?
