Go to Post words of advice: never tease your dad about his receding hair line. it will come back to haunt you. trust me. - Brandon Martus [more]
Unread 26-01-2012, 01:57
Jecht22 Jecht22 is offline
2012 Team President
AKA: John Springer
FRC #2522 (Royal Robotics)
Jecht22 is an unknown quantity at this point
Optimum Wheels for ball shooter
What types of wheels have teams found to work best on pitcher like shooters. Also which sizes of wheels.
Unread 26-01-2012, 22:36
nitneylion452's Avatar
AKA: Joe Lee
Re: Optimum Wheels for ball shooter
This is really something your team should experiment with. Use different motors, different gear ratios, wheels with different traction material and of different radii.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 27-01-2012, 00:24
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
We got out Blue bane-bots wheels today and couldn't be more pleased. They have an Incredible amount of grip on the game piece which means we need less compression to effectively shoot the basketballs.
Unread 27-01-2012, 02:05
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Do you know what the maximum RPM rating for those wheels is?
I assume you got the maximum diameter.
For maximum ball grip, why did you select the FIRMEST 50A rubber instead of the SOFTEST 30A formula?
-RRLedford
Unread 27-01-2012, 02:27
AKA: Isaak
Team Role: CAD
-RRLedford
Our team color is blue so we got the blue wheels, we got the 3 and 7/8 .5 key bore wheel .8 inches wide. 50 shore A is still incredibly soft, The other lead designer and I preferred durability over a little more grip, and they grip so well anyway that we don't think it will be a problem. The Blue wheels are so grippy in fact, that you can press them into the wheel without applying anything other than normal force to the surface of the ball, and when you remove the wheel little flecks of the Orange paint come off the ball, anything gripper and you would be in danger of shredding both the ball and the wheel. We chose the roughly 4 inch diameter size because it worked nicely with our available reduction on the 500 series motors available, as well as positioning in the robot. These wheels are being used both as Intake and Launcher wheels, and we wanted both to be the same size so the robot has more uniform parts, and the 4 inch size allows us to most conveniently push the intake roller to the frame perimeter.
Unread 27-01-2012, 08:26
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Our initial prototype we used our spare drive wheels from last season (4" x 1.5" Colson Performas) direct drive by a CIM. We like the grip they provided and how they handled the ball, but we weren't getting the distance we wanted.
We switched to a 6" Kitbot wheel with the same compression and while we got the distance we wanted, we started to markup and damage the ball.
For the actual shooter we have 6" x 1.5" Colson Performas.
Unread 27-01-2012, 08:38
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
I think the most difficult thing for us right now is making sure that our wheel choice doesn't destroy the balls. We are using the pneumatic tires from Andymark - the distance is amazing but we have to work on keeping them from shredding the tires.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 27-01-2012, 09:55
Squeakypig's Avatar
Squeakypig Squeakypig is offline
AKA: Mike Coyle
FRC #2851 (Crevolution)
Squeakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond repute
For one of our prototypes we are using 2 kitbot wheels with a taction wheel in the middle (smaller diameter creating somewhat of a 'U' shape). We did notice that we were marking up the ball with this set up so we decided to literally cover all of it in duct tape...it worked! No more marking up the ball and to be honest, I do not think we lost any distance on the actual shot. I sort of looks like a drum now with a depression in the middle. Keeps the balls flying straight and consistent.
Unread 27-01-2012, 10:20
Brandon Holley's Avatar
We will be making our own wheel. Aluminum "rim" with solid PVC endcaps. We will "tread" the wheel by pouring urethane into a 3D printed mold around the aluminum rim and endcaps. We will be using a Shore 70A urethane.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 27-01-2012, 11:29
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Where do you get the urethane and what exactly does a person need to buy to do this?
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 27-01-2012, 11:55
Bruce
For us, urethane and silicone are purchased from a local distributor of Smooth On products in Boston. http://www.smooth-on.com/
You just need some basic framing supplies, wood, nails, screws and a vacuum pump to do it correctly. A lot of the videos on Smooth On's site are pretty useful for beginners. The big thing will be the mold. I have access to a 3D printer so I am able to make life easier that way. You don't need one though. You can just as easily use a piece of PVC pipe, or some other round object if you are molding tread around a wheel.
We're going to mold in a V-shape which is why we will be using the 3D printed mold. However you can accomplish the same thing by using clay with the PVC pipe or other round piece.
If you are really interested in doing it feel free to PM me or do a couple searches on here. A couple teams have had great success doing this kind of stuff.
-Brando
Unread 27-01-2012, 13:01
Bruceb's Avatar
Can you tell me what urethane product you are using. Read about some of them but it is very confusing. If you have had success with one of them could you please share?
THanks
Bruce
Unread 27-01-2012, 13:16
THanks
Bruce
I've had great success with the MoldMax and Task series of materials in the past. The Task series is a urethane plastic, which won't work for our application of tread, we want a urethane rubber. For that, we are either going to use the VytaFlex series or the PMC-770.
If you have to make the actual mold, I would definitely recommend any of the MoldMax-es. My general go-to is the MoldMax 30.
-Brando
Unread 27-01-2012, 13:22
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
In 2006 we prototyped a shooter using wheels similar to AM's Pneumatic and could not find a way to make them play well with poof balls. It seems that any wheel with a texture to it will start to chunk the ball with too much compression or if it hits the wrong way. Try swapping in some 2010 kit wheels or 8" Colsons (going to be heavy) and see what kind of results those wheels get you.
-Dustin Benedict
Unread 27-01-2012, 13:35
The thing with Colsons at that size is that pocketing them out does become easier, which means you can start to get the weight down.
