Go to Post Just once I'd love to see a team come out to the field and say " Team xxxx rejects our reality and accepts yours!" - Koko Ed [more]
Unread 26-01-2012, 22:53
Method's Avatar
Method Method is offline
Method is an unknown quantity at this point
Comprehensive help for camera code
for(UINT32 x = 0; x < particles->size(); x++)
ParticleAnalysisReport& par = (*particles)[x];
if(par.center_mass_x_normalized > 0)
//right
if(par.center_mass_x_normalized < 0)
//left
This is a part of an example of tracking code.
I do not understand the purpose of the for, or why (*particles)[x] isn't just (*particles)
Is particles->size(); returning the number of particles or something? If so, wouldn't the code make the robot cycle through aiming at the different targets?
Unread 27-01-2012, 08:33
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Comprehensive help for camera code
It would indeed attempt to drive towards each particle in turn. I forget if I posted that particular code snippet, but what you'd probably want would be something like this, where you select a favourite particle. For example, here's code that selects the biggest particle:
ParticleAnalysisReport biggest = {0};
  if(par.particleArea > biggest.particleArea) // particleArea may not be the right member... I'm going from memory.
    biggest = par;
if(biggest .center_mass_x_normalized > 0)
//right
if(biggest .center_mass_x_normalized < 0)
//left
Of course, you may not want to drive towards the biggest particle, but rather the most backboard-shaped particle...
For your syntax question:
particles is a pointer to a vector<ParticleAnalysisReport>. Therefore, to call member functions on it like size(), you need to use the arrow operator. To call the square-bracket operator, you need to indirect it using the * first to get yourself a non-pointer vector<ParticleAnalysisReport>.
particles->size() tells you how many particles there are in the list of particles.
