Go to Post We must remember: if you're reading this comment right now you already "get it." - akeisic [more]
Unread 26-01-2012, 16:14
shanaynay shanaynay is offline
shanaynay is an unknown quantity at this point
"Robots don't quit" error
We have been getting a "Warning: robots don't quit" error every time we run our code. Does anyone know of a way to fix it? Thanks a ton!
Unread 26-01-2012, 16:28
kingkurry kingkurry is offline
FRC #4067
kingkurry is an unknown quantity at this point
Re: "Robots don't quit" error
We are getting the same error, and after that, it says something along the lines of cRIO: robotDrive output not updated often enough.
Unread 27-01-2012, 09:53
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
You shouldn't see that message unless:
A) You overrode either the robotMain() or startCompetition() method, and your method actually exits instead of looping forever. See SimpleRobot.startCompetition() for typical control flow.
B) An exception occurred which was not caught by your robot's code. In this case, the exception stack trace should have been printed.
Unread 27-01-2012, 13:21
AKA: Brad
#0190 ( Gompei and the Herd)
Like Derek said, it is usually an exception in the program that causes that message where something crashed in your program, it caused an exception (java error), and nothing responded the error.
If you can't find it, please post the rest of the output for a single run of the program.
Brad
Brad Miller
Robotics Resource Center
