Go to Post Fire and smoke are great if you're into Battlebots, but we like to avoid them in FIRST competitions. - [more]
Unread 13-01-2012, 21:45
swootton swootton is offline
AKA: Steve Wootton
FRC #4055 (NRG4055)
swootton is on a distinguished road
Re: Error Deploying JAVA
This is the sample code suggested to use in the getting started package. I'll check the lights in the AM. When we enable it nothing happens. We did not do anything with the DB37, should we have?
Unread 13-01-2012, 21:52
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
DB37 Rework
Please note that many, if not all, of the DB37 cables shipped in the 2012 Kickoff Kits were assembled incorrectly. We have posted more information about the issue as well as instructions to fix the cables here.
Click Here for instructions
Unread 14-01-2012, 10:36
AKA: Steve Wootton
FRC #4055 (NRG4055)
Ok, we managed to get the problem fixed. The Crio is now working and the robot can now move in tank drive. The fix for the DB37 cable was all that we needed.
Thank you all for the help. :7
Unread 14-01-2012, 10:38
Captain
Glad to hear you were able to fix it.
Unread 26-01-2012, 22:57
linuxman linuxman is offline
FRC #4310
linuxman is an unknown quantity at this point
Exclamation Re: Error Deploying JAVA
We had had the same error as mentioned in this thread, We took the advice and checked our cable and there was an issue, but that didn't solve that. We are running off of Java on Linux. We also reimaged our cRio to be compiled with LabView and the code compiled onto the robot. The java compiler freezing hasn't changed whether the cable was attached or not.
Unread 27-01-2012, 10:11
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Sorry, there's not enough information to go on. Can you provide a full log of what you're seeing? In fact I'd suggest starting a new thread since your problem seems to be different than the OP.
Good luck!
Unread 27-01-2012, 15:29
touchdownjesus4's Avatar
touchdownjesus4 touchdownjesus4 is offline
AKA: Tyler Vonderhaar
FRC #4028 (Eagle Robotics)
touchdownjesus4 is on a distinguished road
We are having the exact same problem as the OP, hopefully fixing the cable should resolve the issue.
Just to be clear, when I hit the green button in netbeans it should run all the way through without this error after we fix the cable right?
Unread 27-01-2012, 16:04
AKA: Brad
#0190 ( Gompei and the Herd)
When you hit the green button it builds your program, downloads it to the cRIO (using built-in FTP), then reboots the cRIO so your program comes up running.
Fixing the cable will address problems after the program starts. It won't make download properly if it wasn't doing that before.
Brad
Brad Miller
Robotics Resource Center
