Re: Balls under the bumper
I guess we shoulda spent more time playing before we designed our robot...sigh...
I am interested to see how hard/liberal they are with the penalties for getting a 4th ball "into" your robot. I think some teams with 3 balls already in possession are going to end of playing dodge ball on the field in hopes of not gettings a penalty.
I guess it depends on whether or not you're "controlling" the ball under the robot
In 2010 there ended up being a lot more ball entering the frame perimeter penalties than expected, as many of you may remember. Towards the end of the season, they changed the rules to be a bit more generous and I wouldn't be surprised if they do something like that again.
In contrast to 2010 where incursion was a specific rule as you say, in 2012 a robot can legally drive over a ball, only other choices/avoidable scenarios make this potentially illegal. Last edited by JamesCH95 : 27-01-2012 at 12:10. |
We tried with some older bumpers, anything much below 3" seemed to work quite well. Maybe something in one of our respecitve test setups wasn't quite legit?
#8
It may be bumper fabric has something to do with it. We are using a generic heavy cloth frabric. Or maybe how tight the fabric is pulled up the noodle. I think ours is fairly loose. We tried it with our locomotion bot (low bumper) & the ball goes right under it.
#9
Our bumper was mounted to a fixture (two chairs and a piece of c-channel) and we pulled some carpet+a ball underneath the bumper and we'd set the bumper height with a measuring tape. We might get different results if we moved faster or had a looser bumper. Can you quantify "low"? |
#10
#11
Did the ball get pulled under the bumpers, or did the bumpers ride up over the ball? If the bumpers ride up over the ball, how heavy was the bot? Would a heavier robot just shove it out of the way?
#12
We first noticed this with our mecanum test bed which has last year years bumpers on it. Its bumpers are at 5 inches & the balls just compresses & rolls under it. Robot is around 40-50 lbs. The Locomotion bot is 119.9 lbs. (Don't ask how that happened
) It was unpowered & pushed to the ball. The ball compressed & started under the bumper. We stop when it was clear that it was not going to bounce off. We will play with it (oops investigate) more tomorrow. |
#13
In the section of the rules about the game fouls, it says that fouls caused by the opposing alliance will not be counted. Nothing against one of your team-mates jamming a ball into your robot.
