Go to Post Karthik is afraid of the day he can't agasabapathy. - DesignComp [more]
Unread 27-01-2012, 11:53
giantmidget31's Avatar
giantmidget31 giantmidget31 is offline
Eat robots, build waffles.
FRC #0555 (Montclair Robotics)
Team Role: Electrical
giantmidget31 is an unknown quantity at this point
Making PWM Cables
We have heard from other teams that they make their own PWM cables so that they can spend less money and also have them be a custom length. This year, we want to do that. However, upon looking at the prices of cable, connector housing, and connectors, they are turning out to be rather expensive, actually a bit more expensive than buying pre-made cables.
I was wondering where teams who do this buy their cables, because either I was misinformed or I'm just looking on the wrong websites. Thanks.
Unread 27-01-2012, 12:18
StealthMentor StealthMentor is offline
FRC #1802
StealthMentor is an unknown quantity at this point
Re: Making PWM Cables
This is where we got ours. Good prices, good service. Support the small buisness. They are cheaper than premade, and you get to make them to length so they look nicer. They do take practice!
http://www.hansenhobbies.com/products/
Unread 27-01-2012, 12:37
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
We bought from Hanson Hobbies. Still think we didn't get the best price, but we got what we needed. We also bought their PWM crimping tool that makes those tiny connectors a lot easier. http://hansenhobbies.com/products/connectors/
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 27-01-2012, 13:26
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
The pwm spots on the digital side car are actually designed for molex connectors(surprise right? Part number is in their documents). And the male connectors are available on digikey. I don't have the thread of the top of my head but a quick search for making your own pwm cables will pull it up. Just crimp, assemble and succeed.
Not cheaper, but is neater and connects easier.
Unread 27-01-2012, 14:13
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Hansen Hobbies is great and I haven't found a better price. If you make the PWM cables so that the clips that hold the pins in point towards the clip on the sidecar, they latch and hold pretty well, though I'm sure not as well as the proper Molex connector would.
Jason
Unread 27-01-2012, 15:39
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Here's some Digikey Part numbers, in case you're interested. I'd also recommend picking up one of the crimping tools, as they're really useful.
Male connectors: WM2515-ND
Female connectors: WM2512-ND
3 connector housings: WM2801-ND
3 conductor wire: A121-500-ND (note, this is not the Red/Black/White flat wire that you're familiar with, but it'll function just the same, and I'm pretty sure it's cheaper - at least it was this time last year)
Unread 27-01-2012, 15:44
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
another good way is to buy pre-crimped cables. Pololu sells some nice ones that I've used for all sorts of projects. Use the 12" ones on the bench for testing, then use the other lengths (up to 60") on the robot.
Wires housings
if you have some kind of sensor that goes from two Digital ports to a single connector, you can make the right combo cable.
The other advantage to this is that you have 8 colors to choose from for the signal wire, so you can color code which cable goes to which speed controller for a quick sanity check.
Unread 27-01-2012, 15:53
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Is it me or is the price at Digikey much more expensive. I just ordered 300 male and female pins, as well as 100 feet of cable from Hansen Hobbies
Hansen Hobbies
$17.13 - 300 female pins
$17.13 - 300 male pins
$30.95 - 100ft cable
Digikey
$25.67 - 300 female pins
$41.57 - 300 male pins
$194.76 - 500ft cable Only comes in spools of 500
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 28-01-2012, 08:25
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We're making our own as well.
Housings: Molex 50-57-9003
Female contacts: Molex 16-02-1114 These are called "high force" contacts and should stay put while the robot is getting beat up.
I really don't like the formed male contacts. We've gone a different route and are making our own using the female contacts and soldering 0.025" header pins into them prior to crimping. It takes some time doing this with 0.016" solder under magnification, but were getting stronger, straighter pins. Make sure you're using the right crimper and pull-test every pin.
Just about any 22AWG wire will do. We're using very finely stranded stuff (about 100 strands) intended for high motion applications.
Unread 28-01-2012, 08:44
What issues have you had with the male contacts?
Unread 28-01-2012, 09:02
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
The formed males can be very fragile. The slightest accidently bend and the pin may break off. Hansen sells double ended (solid pin) male "headers" that have long pins at both ends (as opposed to long one end, short the other). We made our encoder connectors all female, and used a piece of that header to turn one female end into a male. Not sure if that would work for connectors targeted for victor with its hooded pwm connector.
Unread 28-01-2012, 09:56
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
If you are willing to solder each pin and do a bit of finishing work you can also use snap-able headers in either male or female format. Snap off a 2 - 3 - or 4 pin section solder wires and finish with heat shrink for a custom connector. You may need a small dab of epoxy in some situations to hold the pins better and produce a more rugged connector. The female version requires sacrificing one pin for each cut and some sanding or filing to produce a clean edge.
You can also epoxy three 14 pin lengths together and solder them to a piece of proto-board to build a digital I/O breakout board. Add other connectors and pins to build a custom connector that allows you to access the signals for testing without removing the PWM connectors, or to transition to some other type of connector to get away from PWM cables entirely. At least at that end.
This is the zeroth day of the rest of your life.
