Go to Post You can't learn anything without breaking some stuff. - DonRotolo [more]
Unread 27-01-2012, 12:41
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Fixed Angle vs. Adjustable angle Shooter
We're facing the same dilemma, and attempting to make the decision within the next couple of days. The main disadvantage we see to a fixed-tilt shooter is the need for a moderate take-off angle at the key and beyond (30-45 degrees) versus a steep angle if we wanted to make a high basket from up close, like touching the fender (75-85 degrees). Not that we're pursuing a strategy of scoring from all over the field; we're just trying not to limit our choices too early in the season.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 27-01-2012, 12:57
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Again, we too faced this same question.
Because simplicity is one of our key goals in designing our system, we really had to decide which would give us the greatest control.
We knew we already needed a way to have reliable RPM for the shooter, so we choose to go with that for our primary control over distance.
Once we prototyped a couple of different designs, we also decided to add a two position hood.
So, our final solution.......both.
Unread 27-01-2012, 13:50
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
My team sees a little bit of benefit to being able to adjust the angle of the shot, even if it is just 45* OR 75*, we want there to be some control over it. We prototyped some designs for throwers, and now that we've got one that we like, we're in the process of constructing a fixed 45* thrower, just to have a final, to-spec design that we can pass off to the programming sub-team. This way they can start getting the measurements they need to calibrate aiming code, and while they're doing that the mechanical sub-team will get to work on building a variable angle "hood" (for lack of better term). It should be interesting how each team solves the same problem!
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 27-01-2012, 18:17
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
We decided on a fixed angle. Our prototype shot well up close and from the top of the key at 60 degrees. We're going to try 70 degrees today to compare.
