Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
Unread 27-01-2012, 13:50
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Fixed Angle vs. Adjustable angle Shooter
My team sees a little bit of benefit to being able to adjust the angle of the shot, even if it is just 45* OR 75*, we want there to be some control over it. We prototyped some designs for throwers, and now that we've got one that we like, we're in the process of constructing a fixed 45* thrower, just to have a final, to-spec design that we can pass off to the programming sub-team. This way they can start getting the measurements they need to calibrate aiming code, and while they're doing that the mechanical sub-team will get to work on building a variable angle "hood" (for lack of better term). It should be interesting how each team solves the same problem!
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 27-01-2012, 18:17
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
We decided on a fixed angle. Our prototype shot well up close and from the top of the key at 60 degrees. We're going to try 70 degrees today to compare.
