Go to Post To me, every robot is a moving mechanical art form, a sculpture made of aluminum, motors and gears, and I think that soon we will be seeing those art forms involved in some of the most fantastic robotic "dances" that any of us have ever seen - DougHogg [more]
Unread 01-27-2012, 04:04 PM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Error Deploying JAVA
Originally Posted by touchdownjesus4 View Post
We are having the exact same problem as the OP, hopefully fixing the cable should resolve the issue.
Just to be clear, when I hit the green button in netbeans it should run all the way through without this error after we fix the cable right?
When you hit the green button it builds your program, downloads it to the cRIO (using built-in FTP), then reboots the cRIO so your program comes up running.
Fixing the cable will address problems after the program starts. It won't make download properly if it wasn't doing that before.
Brad
Brad Miller
Robotics Resource Center
