Go to Post My sister's husband told me when I was just a wee one, "momentum will take you where traction will not." - Joe Johnson [more]
Unread 27-01-2012, 18:28
Re: Specificity in Command Classes
You should be able to make a TurnTurret command that takes a parameter of how much to rotate the turret. Then to turn the turret right, you pass positive values and to turn it left pass negative values or visa-versa.
Unread 27-01-2012, 20:13
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
I agree. Just put the degree you want to turn in the constructor of your Turn command.
