Go to Post we learned that's what happens when you start building without even thinking about weight. next year, we'll lighten everything BEFORE we mount it. - greencactus3 [more]
Unread 27-01-2012, 18:50
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Matrix Bot LV-MaxSonar-EZ1 Code?
what class do we use for the LV-MaxSonar-EZ1 ?
do we use the ultrasonic class, if so, what are the ping and echo slots?
it seems like the ultrasonic class is for older sonar sensors so what do we use?
Unread 30-01-2012, 15:28
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Matrix Bot LV-MaxSonar-EZ1 Code?
I don't think the ultrasonic class works with this sonar sensor. You should just instantiate an analog channel for this sensor (if you are connecting it via analog input).
Unread 30-01-2012, 22:06
DonRotolo's Avatar
Back to humble
FRC #0832
Use an Analog channel. Each inch = 0.01 volt, so you'll see 0.73 volts for 73 inches, for example.
