Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 27-01-2012, 19:24
SeanBurger SeanBurger is offline
FRC #2129 (Ultraviolet)
SeanBurger is an unknown quantity at this point
Axis Camera 206 not reading target.
My second year programming. I have followed the directions on integrating the example vision code into my project. I can track the rectangle when I run the program, visionprocessing.vi from the example, on my laptop. I have the program set up to display the target information on the classmate's driver station but it doesn't show up. I don't know if it's actually working. What if anything am I doing wrong?
Unread 27-01-2012, 20:10
Re: Axis Camera 206 not reading target.
In order to debug it, I'd either open the global panel, or probe the wires while the camera is pointed at the target. If the target is being tracked and the global updated, the problem is further towards the DS printing. Track it down with additional probes.
Greg McKaskle
Unread 28-01-2012, 11:18
The global data is reciving the target info, but the telop.vi is not. the wires for all the 9 targets aren't returing any data. I'll continue to probe anroung to try to find an answer.
Unread 28-01-2012, 12:15
I have found one potential problem while running the programs on my computer. I can run the vision processing or the telop but not at the same time. Is there any way to fix this?
Unread 28-01-2012, 16:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If you have integrated it into your program, you should be running from robot main. That, in turn, will run both the vision processing and the teleop code in parallel.
