Go to Post i wish ours was done so i could get some sleep - keagara [more]
Unread 27-01-2012, 19:24
evilcrouton evilcrouton is offline
FRC #2851
evilcrouton is an unknown quantity at this point
SmartDashboard and Camera
Has anybody been able to stream the camera feed to SmartDashboard? I am having trouble because there is no documentation on it. All I know is that it is possible thanks to WPILib Cookbook.
Unread 28-01-2012, 19:44
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: SmartDashboard and Camera
Yea, its easy in Smart Dashboard goto View>Add>Camera and put the ip address of the camera by View> editable then double click the camera box
Unread 31-01-2012, 17:30
FRC #2851
I have done as u said. The problem I am now encountering is the camera LED indicator on the front is blinking green and I am still not receiving any feed. Anybody understand what this means?
Unread 31-01-2012, 18:00
FRC #0228 (Gus)
Have you configured the ip of your camera?
Unread 31-01-2012, 18:06
FRC #2851
Yes I have configured the camera with the utility that FIRST provided. Our Camera is set to 10.28.51.11. I also checked the box for anonymous connections.
Unread 31-01-2012, 18:16
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty
I'm having the same issue.
John Fogarty
Unread 01-02-2012, 11:47
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
I had this same problem, connect to your camera through your browser at 10.Te.Am.11 and turn "Anonymous Viewing" on
Of course you need to replace Te.Am with your team number.
(For example, I would go to 10.32.60.11)
Once you are there it is one of the two? options on the setup page.
Unread 01-02-2012, 17:14
FRC #2851
Problem Solved. It was kind of a mishap on our part. We made a custom camera mount. It fit so snug that it was perpetually holding down the big reset button on the back of the camera. After we rectified the mount and reconfigured the camera, the camera feed appeared. Thank You for all of your support.
