Go to Post When you build a practice robot, you're literally buying time. - sanddrag [more]
Unread 27-01-2012, 15:28
Re: paper: Simple Motor Calculator
Originally Posted by bmlarson12 View Post
WOW!!! How did you do this? I have been looking for a graph of the information so I could get the general values, but this is far better!
If you assume that the speed vs torque and the current vs torque "curves" are straight lines (which is the standard assumption for almost all the motors used in FRC), then most of the equations are fairly straightforward to solve explicitly.
For example, at the rated voltage and for a given torque tau, you can find the speed as follows:
speed = free_speed*(1-tau/stall_tau)
some of the other calculations, for example solving for efficiency or finding voltage when given rpm and torque, are a bit trickier, but not too bad.
I'm glad you discovered it and hope you find it helpful.
Unread 27-01-2012, 16:37
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Ether == Awesome - any chance you'll part with the source so I can compile a Linux version?
TIA
Unread 27-01-2012, 19:31
It would be good to have a Linux version.
I'll pull out the formulas and post them.
Give me a couple of days.
Unread 27-01-2012, 19:41
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
If it was a windows console app, it will probably just compile and run quickly with minor changes. You can send the source if you want.
Unread 30-01-2012, 11:08
Here ya go.
Unread 30-01-2012, 14:15
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Here ya go.
I'm a busy guy - no time soon to re-write the program, not with work for 3 customers in process and being in the middle of build season. I apologize if I was not clear. I was offering to take your source and re-compile to create a Linux executable. No disrespect intended but I don't need the formulas ;o). I'm an EE and have been designing opto-mechatronic embedded control systems for 30 years - I know the formulas.
Thanks anyways.
Unread 30-01-2012, 15:35
Of course. I thought you were after some of the more arcane calculations, like solving for operating range given operating volts and desired minimum efficiency*. I've never seen that published anywhere.
Anyway, unless you have an old copy of Kylix the source wouldn't serve the purpose intended.
Oh well, the equations are out there for anyone who might be interested.
*it's not as useful as other calculations, I know, but I included it because it's interesting to play around with and may provide some insight
Unread 30-01-2012, 15:38
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Well, it just so happens that I do ... BTW, FIRST Team 1296 very much appreciates all the great advice you regularly disperse on CD!
Unread 21-02-2012, 01:28
There have been a number of occasions recently where I wanted to calculate a motor's applied voltage given rpm and amps. To make this more convenient I added another option to the motor calculator.
I have also changed the display to show waste heat watts instead of input watts, since that seems to be of somewhat more interest. Input watts is easily calculated by adding output watts and waste watts.
Unread 12-01-2013, 17:56
Thread created automatically to discuss a document in CD-Media.
Simple Motor Calculator by Ether
New version just uploaded. Includes VEX MiniCIM and BAG motors.
Unread 26-01-2013, 13:13
Motor Calculator has just been updated to include the now-legal Banebots M5-RS555-12 motor.
The new version (MCALC_2013b) is at the bottom of the list of attachments.
Unread 27-01-2014, 17:58
Motor Calculator has just been updated to include all 2014 motors. Sorry for the delay. Better late than never :-)
http://www.chiefdelphi.com/media/papers/2432
Unread 03-02-2014, 13:33
Motor Calculator has just been updated to include am-2161 & am-2194 motors (for am-0914, 2193, & 0915 gearmotors)
Unread 03-02-2014, 20:10
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Thanks again Ether!! You would not believe how much we use this utility.
Unread 03-02-2014, 21:25
yash101 yash101 is offline
AKA: null
Cool Re: paper: Simple Motor Calculator
THAT IS SWEET AND USEFUL
