Go to Post People are human, refs are human. The refs did the best they could do at the time. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 27-01-2012, 20:11
MormonLad MormonLad is offline
FRC #3556
MormonLad is an unknown quantity at this point
Question Bumper Rule Question
According to the bumper rule (R27) we need at least 8 inches of bumper space on each side of each exterior vertex. My question is, even if we don't have 8 inches of frame on each side of the vertex, do we just cover all the available space, or do we have to extend the frame? Please help.
Unread 27-01-2012, 20:19
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Bumper Rule Question
Start with the Team Update from 1-17:
[R33]
Bumpers must be supported by the structure/frame of the Robot (i.e. each end of the Bumper must be rigidly attached to the Frame Perimeter, the gap between the backing material and the frame must not be greater than ¼ in. and no section of Bumper greater than 8 in. may be unsupported). See Figure 4‑7.
And end with the Q&A forum answer:
Q. Pertaining to R33, namely the (i.e) line about the ends of bumpers needing to be attached to the frame perimeter, does it mean that the vertices of the bumpers need to be attached, or does the rule mean to specify a different type of “end”? If so, how far away from the corner can they be attached?
A. The specific part of Rule [R33] referenced means that Bumpers may not extend beyond any segment of Robot frame beyond that which is expressly permitted in [R28] and the rest of [R33] regarding unsupported sections.
Unread 27-01-2012, 20:32
SteveGPage's Avatar
SteveGPage SteveGPage is online now
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Can you attach a sketch of what you are asking? Are you saying that one side of your robot is less than 8 inches, or are you saying that you have less than 8 inches on a segment of your frame adjacent to an exterior vertex?
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 27-01-2012, 20:59
FRC #3556
We have a 32 1/2 inch frame with a 19 inch gap in the middle for ball intake, with 6 inches on each side. So can we just have 2 inches of bumper over hang, or do we have to make the frame wider?
Unread 27-01-2012, 21:03
SteveGPage's Avatar
AKA: Steve
That configuration would be illegal. You need to have 8 inches on each side. You cannot have the 2 inches of bumper over hang. See Team Update 2 (January 13) for more information.
http://frc-manual.usfirst.org/TeamUpdates/0#term 86
Unread 04-02-2012, 16:12
adrianfarmer's Avatar
adrianfarmer adrianfarmer is offline
FRC #3556
adrianfarmer is an unknown quantity at this point
To clarify our question: In the front and back of our robot, there is an opening for the balls to go through. On each side of the opening, the frame of our robot is only 6.25 inches. Our question is if we don't have 8 inches of robot to cover, do we just build our bumpers to fit what we have?
SHOULD never means DOES!!!
Unread 04-02-2012, 16:27
EricH EricH is online now
Your frame perimeter is defined by the external vertices of your frame, not the frame itself.
You build the bumpers 8" long and rebuild the frame to support them as required by [R33]. Bumpers measuring less than 8" from the vertices of the frame perimeter are grounds for not passing inspection.
Unread 04-02-2012, 18:32
DonRotolo's Avatar
Back to humble
FRC #0832
To make it even clearer: You MUST have 8" of frame, 6.25 inches is 1.75 inches too short.
Unread 07-02-2012, 00:18
nitneylion452's Avatar
AKA: Joe Lee
They could get away with a support on the other end. That is their 6.25" of bumper, a 1.75" gap and a piece of c-channel behind it supported by something attached to the inner part of their frame. I'll post a drawing in a bit to make what I'm saying easier to visualize.
Name:	bumper backing.png
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 07-02-2012, 08:04
Al Skierkiewicz Al Skierkiewicz is online now
Perhaps it is easier to answer that all bumper rules must be satisfied. That is, 8" on either side of an exterior vetrtices, and supported at the ends, and no gaps in the frame larger than 8", and small gaps of less than 1/4" are allowed when those gaps are generated by hardware, welds, or frame joiners, etc.
Unread 07-02-2012, 08:47
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
[R33]
(emphasis mine)
Wouldn't that be impossible though, at least for two of the bumpers? Doesn't the wood have to overlap the wood of the perpendicular bumper? How would the end be rigidly attached to the Frame Perimeter then? Or is 'end' a relative term, and just means 'as close to the end as possible'? I have an example picture below:
Thanks in advance.
Unread 07-02-2012, 10:11
Ryan,
The picture shown is a new, allowable corner defined by the GDC this year. The thought being that one bumper gives support to the other and teams who wish to design one piece bumpers can take advantage of this new ruling to strengthen the corners.
Unread 07-02-2012, 10:59
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
Ryan,
Ah, thanks. My apologies, I missed the previous image showing that the perpendicular overlap is not needed (as shown below).
Unread 07-02-2012, 14:51
gearheadcapital gearheadcapital is offline
FRC #1189
gearheadcapital has a spectacular aura aboutgearheadcapital has a spectacular aura about
I have one question regarding what Mr. Skierkiewicz wrote. Specifically, he said there cannot be a gap in the frame of more than 8". I didn't read that proviso in the rules. Does this mean we cannot have more than an 8" segment cut out of the frame or does he mean that the bumper cannot cover more than an 8" cut out in the frame? Put another way, can you remove more than an 8" segment of frame perimeter, provided that there is at least eight inches on either side of that opening or are you limited to an 8" maximum opening?
Unread 07-02-2012, 15:00
[R33]
Bumpers must be supported by the structure/frame of the Robot (i.e. each end of the Bumper must be rigidly attached to the Frame Perimeter, the gap between the backing material and the frame must not be greater than ¼ in. and no section of Bumper greater than 8 in. may be unsupported). See Figure 4?7.
Al forgot to specify that that gap was behind the bumper. You can remove more than 8" of frame perimeter, provided that you do not try to mount bumper across the gap, and provided that you leave the required bumper areas at the corners fully supported.
