Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 27-01-2012, 21:02
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Robot looses comms when hit/jolted
Originally Posted by ttldomination View Post
We had a similar issue back in 2010 whenever we would kick the ball (caused the entire bot to shake). Apparently the power connector to the cRio was lose. Check that out.
- Sunny G.
The wires going into the cRIO or the black connector? thanks!
