Go to Post You valuable advice has prevented me from killing myself and others numerous times =) - Stephen Kowski [more]
Unread 26-01-2012, 14:40
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Motors not working with jaguars
The document entitled "Getting Started with your 2012 Control System" located here goes step by step on configuring your Control System.
I assume you are somewhere on page 25 but you should go through this document and verify every step has been performed. Also, while you can use one of the Example Projects (on the Labview Splash Screen click Support and then click "Find FRC Examples" the Default Project has code in it already to control a simple drive-train, to help new teams get started. Which this document references.
Unread 26-01-2012, 18:15
AndresC AndresC is offline
AndresC is an unknown quantity at this point
Problem has been fixed. We forgot to put the jumper on the Analog breakout. Everything else was connected properly.
Unread 26-01-2012, 20:53
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Erm, that problem would have no effect on Jaguar communication barring some ridiculous short through the breakout. The jumper allows you to see your battery readout accurately, not regulate speed controller signals.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 27-01-2012, 00:09
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Analog breakout? That has nothing to do with the jaguars. If you are talking about the servo jumpers on the DSC, than there is still something wrong, you shouldn't need those. The only possible thing I can think of that would make this solution make sense would be the new CRIO image disabling all outputs when it can't read battery voltage.
Unread 27-01-2012, 21:07
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
The crimp coming from the cim to the jag seems to be coming out via your picture
Unread 28-01-2012, 16:32
Ringbearer31 Ringbearer31 is offline
FRC #3181
Ringbearer31 is an unknown quantity at this point
From your question, you do not state you tested it with victors, so I'm going to assume "no". If your useing your shiny new ribbon cable, try something else. Thats broken. You can fix it with these instructions, but they are easy to break even more.
