Go to Post How about "Lebron"? Wait, no, you'll be dooming yourselves to failure the last 30 seconds of every match. - Travis Hoffman [more]
Unread 01-27-2012, 09:35 PM
tap13 tap13 is offline
AKA: PatrickA
FRC #3481 (Bronc Botz)
tap13 is an unknown quantity at this point
FRC Drive Station help. No robot code!
Hello!
I'm totally new at the forum, so please be nice...
We're having problem loading the robot codes to the cRio..
We're using Windriver, C++..
We're using an ethernet cable to connect to the cRio
here's a screenshot
[spoiler]
[/spoiler]
Can you please give down any suggestions to fix our problem
Much help is appreciated!
Unread 01-27-2012, 09:44 PM
Glen Glen is offline
FRC #1444
Glen is an unknown quantity at this point
Re: FRC Drive Station help. No robot code!
I would try formatting the cRIO with the FRC 2012 cRIO Imaging Tool. When you do so, make sure that you select Windriver c++ as the option. Once you have done that, try compiling and deploying your Windriver c++ code to the cRIO.
Unread 01-27-2012, 10:09 PM
AKA: PatrickA
Problem still persist
Unread 01-27-2012, 10:17 PM
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Can you be more explicit about what the "problem" is? I see from the screen shot that the "Robot Code" light is red in the driver station. Is there anything wrong with the output from downloading the code? Similarly, is does the imaging tool complain at all?
Unread 01-28-2012, 03:22 AM
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
Have you tried this?
http://www.usfirst.org/sites/default...structions.pdf
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
Unread 01-28-2012, 08:41 AM
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Make sure firewall is off on DS computer.
Turn off wireless adapter on DS computer.
Has ribbon cable been checked for improper assembly? From the picture it appears that this is one of the cables that needs to be reworked. See article on KOP Control System web page. http://www.usfirst.org/sites/default...structions.pdf
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 01-28-2012, 11:04 PM
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
This would make no difference, as to only sending signals to the Digital Side Car. When you deploy the code is it loading onto to the robot? Are you using the YELLOW crossover cable? Are you sure you changed your computers ip to whatever it is suppost to be? Same with the subnet: 255.0.0.0? Turned off the firewall?
Unread 01-29-2012, 01:29 PM
AKA: PatrickA
We fixed it it, thanks for the replies!
Unread 01-29-2012, 01:31 PM
Great explanation on how you managed to do it!
Unread 01-29-2012, 09:55 PM
AKA: PatrickA
yeah, it was actually the codes, we were loading the wrong codes...
Unread 01-30-2012, 01:34 PM
pmuller pmuller is offline
FRC #2871
pmuller is an unknown quantity at this point
Could you describe what you mean by the wrong codes? I am having a similar problem. Thanks. -Paul
Unread 01-30-2012, 02:40 PM
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Assuming that you are using C++, remember to reboot the robot each time that you load your code. (Java should do this for you)
Also, make sure to check that you don't have an incorrectly assembled ribbon cable. That will cause a TON of really odd and inexplicable problems.
Unread 01-30-2012, 03:01 PM
Fythal Fythal is offline
FRC #0781
Fythal is on a distinguished road
I think i know what tap13 was talking about when he said "we were loading the wrong codes..." as we had run into that problem before as well.
The problem was that we were sending the wrong file to the robot when we deployed code in WindRiver.
What we did to fix this was the following...
0) open up windriver
1) go to Window > Preferences > FIRST Downloader Preferences.
2) change the file you download to the robot by clicking the browse button.
4) navigate through the project you wish to deploy until you find the .out file. then click open. you should now have something like this...
C:\WindRiver\workspace\2012_Robot_Code\PPC603gnu\S impleTemplate\Debug\SimpleTemplate.out
**Please Note** you have to build your project first in order for the .out file to appear in the debug folder.
Anyways, thats what we did when we had a No Robot Code error on our Driver Station.
Hopefully that works for you pmuller!
Unread 02-12-2012, 11:27 PM
shaikr shaikr is offline
FRC #4384
shaikr is an unknown quantity at this point
Hi
We are having similar problem with Labview. Using the sample code to test the bench top setup and the dash board show no robot code. We have double checked the connections and the cable has been corrected. Any idea how to resolve this?
Thanks
