Go to Post Who knew a single variable could be so deadly? - 3DWolf [more]
Unread 27-01-2012, 16:24
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Connectors for Jaguar encoders
Good afternoon everyone.
I am looking for a connector/how to connect the US Digital E4P quadrature encoders to the jaguars encoder port. I tried using the black connectors with metal crimps that go in them that we received one year in the KOP, but to no avail, they are too fat. I haven't tried a PWM connector, but I think they are the same size, but I may be mistaken. Any ideas?
Thanks.
"No, you can't use the Kinect to do pelvic thrusts."
Unread 27-01-2012, 21:59
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Connectors for Jaguar encoders
These connectors should be compatible.
Unread 27-01-2012, 23:05
jp1247's Avatar
FRC #1247 (ROK BOT)
Those appear to be the ones that connect to the encoder itself, correct me if I'm wrong. I'm looking for a connector that will work on the physical jaguar, as the pins on it are not in the same order as the encoder.
Unread 28-01-2012, 22:47
jmailhot jmailhot is offline
FRC #0303 (Panther Robotics)
jmailhot is an unknown quantity at this point
There are a lot of different five-pin box headers, and some fit and some don't. As you have seen the opening has very little clearance.
This year I purchased a wide selection of box headers and pre-crimped wires from pololu, and their 5-pin box headers fit into the slot on the Jaguar just fine. The crimped pins slide in nicely (once you learn how to orient them) and appear robust.
Pololu Website
Link to the 5-pin headers
Pololu shipped next day even though i ordered at midnight, and stuff arrived as promised.
Unread 28-01-2012, 23:20
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Try Hansen Hobbies, we use them for all our PWM and other .1" connector needs and I haven't found a better price. I highly recommend this, from the same site, for crimping the connectors. It's almost impossible to get a good crimp without the right tool. The wire there is a great price too, but they only have 3-conductor wire.
Jason
Unread 29-01-2012, 12:06
DonRotolo's Avatar
Back to humble
FRC #0832
Both Digi-Key and Jameco sell connectors that are compatible. Those are examples, there are many to choose from which may fit your needs better.
